Cleaning Ultraview UV70
grahamdown
Post by grahamdown »
Does anyone have an easy way of cleaning Ultraview UV70 as it always seems to have small grease marks straight out of the box. i've found Nilglass doesnt work and isopropyl alcohol isnt brilliant.
i seeem to be selling more and more of this glazing hence its becoming a bigger problem.
all suggestions very gratefully received.
Graham
Re: Cleaning Ultraview UV70
Teepol make some very seriously powerful detergents, one of them is called Teepol trafic film remover. This is seriously good at removing grease, smudges and contamination from glass. I have used it while during my career working in high tech industries. It's not cheap, but the best never is! It is an industrial grade cleaner and shifts the surface contamination, which most other cleaners won't touch.
Teepol make a huge range of industrial detergents and cleaners, it may be interesting to check out their range of products. Many of their products are some strong that you will need to be aware that they can strip the natural oils from your skin and maybe it will be good to use a moisturising hand cream if you get any on your hands, in order to replace the natural oils that are normally present on your skin.
I'm not joking this stuff nukes oil, grease, smears and just about any contamination, that normal detergents won't touch. It's used for cleaning the optics for inside gun sights, periscope optics and stuff like that. A lot of their products are used in grade 1 clean room assembly areas. If you want the best, this is it!
JonathanB
Post by JonathanB »
Graham -
I've been using Opti-Bright from Wessex for quite a few years and never had any issues with it. Use it with a microfibre cloth and you should be fine. They do a small 150ml bottle if you want to give it a go.
Best wishes
Jonathan
Jonathan Birch GCF (APF)
David McCormack
Organisation: Framing
Post by David McCormack »
Opti bright from Wessex for me too :yes:
Me three, with the antistatic panther wet cloth and tiger dry cloth.
I just use a soft cotton cloth and huff on it, as you would with a camera lens or a pair of glasses, I find it quite breath taking :giggle:
Huffing? That's old school Steve! :lol:
That's me all over , old school :clap: :lol:
Ed209
Post by Ed209 »
All from Wessex
Opti bright
M Tork paper roll
and change to Art Glass
all your problems will be as solved
grahamdown
sorry not to have come back before but does anyone else find Art glass easier to clean than trueview?
YPF
Post by YPF »
We use Artglass supplied by Centrado. They are delivered in packs of 4 with polythene sheets between each piece. Very rarely is there a mark on the glass - we use a soft microfibres cloth (only used on Artglass) to give it a gentle wipe over to remove anything that may have landed on it after cutting. If there are any other marks on it then it is us that have probably caused them. I can’t remember the last time I found a mark on Artglass straight out of the box.
Steve
Chief Coffee Drinker
+Rafe+
Organisation: The Nunhead Framer
Interests: Theatre, film, the arts, a bit of this, a bit of that
Post by +Rafe+ »
I was having the same problems then moved back to Art Glass and life is much easier!
+Rafe+
Post by +Rafe+ »
