Large print mounting (on kappa board or similar)
Posted: Mon 02 Aug, 2021 2:37 pm
Hello everyone,
I need to mount a large print (roughly 1.5m x 1.25m, 60 x 50 inches) to a kappa mount board.
Even though the print is heavy paper 325gsm, it will bend in places if only using tape hinges. I tried and it will never hang flat enough because of the size.
To stick this print down completely, what are my options.. Spray glue for such a large area? Is there a pouring glue thin enough that I can roll it out smoothly with a rubber roller before sticking the print on? Or double sided mounting adhesive film (in such a large size?).
Any idea what would work best or you've used before? Because of the size, there's no way I could just try things out and see what happens
Thanks so much for any ideas!
Alex
Alex
