Excalibur adjustment
Abacus
Post by Abacus »
My Excalibur 5000 has developed “slop” in the head, I.e. it moves on the vertical post. Is there any way to adjust this? It’s not that old but has had plenty of use.
GeoSpectrum
Re: Excalibur adjustment
Post by GeoSpectrum »
    I had the same. There are white nylon shaped sliders that run on the alloy vertical. Tighten these with the appropriate Allen key.
    Abacus
    Post by Abacus »
    Hi Alan
    Thanks for the reply, I had a look and couldn’t spot the Allen screws, are they teeny tiny?
    Vince
    Gesso&Bole
    Post by Gesso&Bole »
    If you look on keencut.com, and then go to support, and then select excalibur, there will be instructions on solving all known problems
    Abacus
    Post by Abacus »
    Thanks Alan I’ve managed it. Just the silver acres, not sure what the black ones are for, but it’s done the trick.
    Thanks again.
