Firstly I traced the outline of the mag in soft pencil then cut a one inch slit top and bottom centre - just on the inside of the line. Then I made half inch cuts 2" away from each corner and erased the line.
Then cut some strips of melinex (clear polyester film) from offcuts.
The wide central one holds all but the front cover in place and the narrow ones at the corners hold it all straight and stop the pages from flopping open - these corners alone are no good.
There was a bit of adjustment after this shot - the corner straps were a bit too tight
By cutting the slots just on the inside of the pencil line they cannot be seen unless you try really hard
Melinex is available from PEL in sheets, on rolls and in shedloads of bags and envelopes - an envelope would be another option but not in this case as museum glass was used so we didn't want a big glossy sheet over the whole surface.
