easel strut backs
Posted: Mon 13 Feb, 2023 7:05 pm
by daveym
Does anyone know if there are suppliers here in the UK that can produce these according to a specific size or would these need to be manufactured abroad?
I'm specifically looking for a hinged style heavy duty cardboard strut back with a rear access door to hold a 6x4" photo/picture within a hand made ceramic frame...other smaller sizes may also be required. I've explored a variety of ideas and these would seem to be the most practical.
I can only find a single supplier in the US and they offer only limited options that don't fit the size of frame.
Re: easel strut backs
Posted: Tue 14 Feb, 2023 12:02 am
What quantity? For a company to make custom strut backs they would have to spend a considerable amount
'tooling up' which would mean making thousands or hundreds of thousands of backs to make it financially viable.
It's more involved than you might think. :roll:
The alternative is to make them yourself in small batches using a number of jigs. I did some years ago using MDF
and using bars and clips. I think I used over 1000 bifurcated rivets, all set by hand. It was a bit tedious. :?
But they were fairly basic and didn't have the opening 'door', which would have been even more complicated.
I fear there is no simple way of doing this. :(
** Card struts are apt to 'wilt' over time.
Posted: Tue 14 Feb, 2023 10:13 am
by vintage frames
I used to do this.
What you have to do first is design the sort of back you wish to use.
In your case it would be a board which covers the back of the ceramic frame and has a hinged back door to access the artwork. The door will be partially cut out and hinged on one side by a pressed crease in the board.
The strut will be attached by either a press-on metal hinge or even a glued canvas hinge.
The board should be about 2.5mm thick.
Next is to get into conversation with a 'die cutting services' company who will die cut the patterns you need and advise on the best source of board to use.
We used a black fibre board which car manufacturers used for their dash-boards. It had a very fibrous consistency which gave a firm grip on the hinges and came polished on one surface.
It was made then by a company called Olympic Varnish, but they are now extinct.
When you get the shapes back from the die-cutters, you can attach the hinges in-house together with a little press-on closure tab.
Posted: Fri 17 Feb, 2023 2:07 pm
by Gesso&Bole
What sort of quantities and quality are you looking for?
I can probably do them for you
