I need 320 ft of this Simons moulding - the ref is 5412-7008. I was told over 2 weeks ago that it would be in in three weeks and today I was told the end of May.
Wondering if any other supplier does the same one under a different ref - Arqadia do (442 700 000) but it's out of stock until May 20 - but I was told May 17 previous!
Or maybe a Simons distributor has some?
It's 37mm wide and 28mm rebate - brushed silver with a swirled finish rather than a hatched finish.
One hundred feet would be OK too - I don't need all 320 ft at once
Thanks anyway Áine - should've said I've also checked Nielsen, Wessex/Frinton, A&T & Mainline, but I may not have the latest catalogues from the last three.
The Arqadia one is not as nice either - don't think I'd use it even if they had a light year of the stuff in stock!
I think the Arqadia moulding equivalent to the one you show is 441 700 000 (28mm deep rebate) not 442 700 000 (13 mm rebate).
If you can live without the rebate depth could Arqadia supply 442 700 000? I just checked their website and they list 6756 metres in stock so should cover your requirements
I believe Wessex do the same moulding as their stock number D3364 but again shallow rebate.
Having used these I think they all buy from the same source hence all out of stock at the same time.
Well, that was a fuss about nothing - I hadn't checked A&T at all, just listed the supplers whose catalogues I have; assumed I'd checked them all.
A&T's was in a jiffy bag and I missed it - they do the exact same moulding - even the same ref no and had 94m of it which is now winging it's way to me.
I'll post some interesting figures on the Simons thread later!
