Hello, my first post; I would appreciatte your help.
Bottom knives are misaligned and I would like to drop the blades down on an non-foot operated morso; this one is the EH model; with hydraulics.
I have seen a video explaining how to do it but unfortunately it doesnt explain how, I think the video is referring to the foot operated cutter.
Any help will be greatly appreciatted.
Aligning bottom knifes on a Morso EH
ditomiranda
- Organisation: E&R
- Interests: Framing
- Mark Thornton
- Organisation: Underpinner Spares
- Interests: Red wine - lots and lots of it.
Re: Aligning bottom knifes on a Morso EH
The YouTube video is more or less correct except on your eh you need you will let go of the operating buttons just before the blades auto retract that way the cutting head will stay in a low enough position to enable you to adjust the bottom blades.
Whilst the Cs55 in the video looked brand new in reality your Morso will probably have tiny pieces of wood trapped around the blade screw heads so you will need to remove the screws and clean the pieces out to enable the blade position to be reset.
Tip, don’t set the bottom blades too tight to the cutting blades that they rub against each other.
