Underpiner felt profiles
rudgey
Organisation: Art+Frame
Interests: Photography
Art
Post by rudgey »
Does anyone know if you can get different shape felts for underpinners?
rudgey
Art
Re: Underpiner felt profiles
Post by rudgey »
I’m thinking about when joining large curved profiles, would be great to have a selection of different shaped thick felt type of pads.
When I had my old Euro pinner it had a woeful top pad. I dented many a corner. Then I made a wooden triangle
and faced it with 3mm cork and wrapped it in clingfilm. OK, so you have to manually place it on the corner but
it saved a lot of denting. I made one or two other little 'helpers' so as to get the pressure exactly in the right spot.
* The clingfilm can be easily changed when it got gunged up with hardened glue.
** Polyurethane is better than felt for this purpose. :yes:
Some profiles will sit on top of each other in reverse, if bare wood and no details to damage. You can place some offcuts over the top before joining. I'm not an expert at this but I've heard it's done.
rudgey
Art
Post by rudgey »
Thanks for the ideas, I will try to make some up
Stina
Organisation: ER-Ramar Eftr.
Interests: Making and framing art.
Post by Stina »
prospero wrote: Sat 26 Oct, 2024 9:37 am When I had my old Euro pinner it had a woeful top pad. I dented many a corner. Then I made a wooden triangle
I have a Euro underpinner with this top pad. I have dented one or two. Should I change it?
I would like to see a picture of your homemade!
Framer in Göteborg, Sweden
That pad looks a lot better than the one on my Euro which was hard plastic with a very thin felt covering.
My 'helper' was a triangle of wood about 5" wide with cork (from a floor tile) stuck on one side. It spreads
the pressure.
