Dry Mount Board Hanging Conundrum
Posted: Mon 05 May, 2025 10:16 am
I'm framing this poster for the child's bedroom wall, and wanted to try using some foamcore to make a slight gap between image and the mount.
The aperture size is 835x585mm, but overall is 955x705mm with the mount.
Because it's a poster, I dry-mounted it, but made the mistake of cutting the mount board back to the poster/aperture size. If it'd planned better, I would have cut it to the overall size.
Ordinarily, this wouldn't be an issue if it was just a print that I cut suspend with tape from the underside of the mat/foamcore surround. But, because it's on a dry mount and is therefore relatively heavy, I'm concerned about securing this in what is a larger square area for the mount.
How would you get round this issue? I was thinking of doing something like that the attached photo, whereby foamcore is put together with an aperture that will effectively hold my picture/dry-mount in place. Would you do this?
Or...I've cut another piece of foamcore to the overall size and the temptation is to just stick the poster/dry-mount onto that, instead of forming more apertures. How about this tack?
Is this whole scheme too foamcore excessive??
