Large image 1600x600mm
Posted: Tue 17 Mar, 2026 6:24 pm
by chaos
Hello all
I have been asked to frame a limited edition print 1600 x 600mm (small edition size)
The customers would like to use a deep frame - L3370 Mono 19mm wide x 44mm deep with a spacer
I guess I need a subframe?
Drymount it or similar? - is there anything long enough & I don't have a press
3mm Artglass?
Can I use 5mm ply as a backing? Or is there something more suitable?
What hanging system? Heavy duty hangers attached to the subframe?
What else do I need to consider that hasn't occurred to me yet?
Not daunted at all!!
Re: Large image 1600x600mm
Posted: Tue 17 Mar, 2026 7:33 pm
by JFeig
Have you considered acrylic products for glazing or plastic fluted sheets for a backing?
A roller press for mounting as used in the sign industry.
Posted: Tue 17 Mar, 2026 10:06 pm
by framesink
A limited edition and a small edition. Why would you drymount?
Posted: Tue 17 Mar, 2026 10:07 pm
by framesink
Do you know the value of it?
Posted: Tue 17 Mar, 2026 10:54 pm
by Justintime
framesink wrote: Tue 17 Mar, 2026 10:06 pm
If the customer wants it perfectly flat and isn't concerned with potential loss of future value.
You're right though. It's really important to have that discussion.
Posted: Wed 18 Mar, 2026 10:27 am
by JKX
Something that size with such a tiny frame will look terrible IMO.
Anyway - a frame that tiny will of course need a sub frame or bracing in some way, but it it’s still not fit for the job as the spacers are unsafe - glazing that size and weight sitting on maybe 5mm wide spacers? I’d refuse to do it.
Stuff that size I’ve done has usually been in a double frame
eg a 30 mm or so inner acting as a spacer and a much wider outer, so the glazing sits in the outer rebate and also rests on thd inner frame. The two frames can be reversed to give a mounted sort of look, wide frame in place of mount.
Most customers wanting skinny frames on huge artwork are thinking of cost. If I absolutely HAD to make this work the labour costs would scare them off.
Posted: Wed 18 Mar, 2026 1:03 pm
by chaos
Thank you all for your replies.
I told the customer I don't want to drymount it. I prefer anything in I put into a frame to be in the original condition if it ever comes out of the frame. (Apart from sports shirts which should just be burned!
) I just panicked about the length and thought drymounting would be he only thing I could do to prevent ripples when I posted on here.
How do I prevent ripples? Will normal t bars be suitable or should I hedgehog it?
I have considered acrylic glazing. I have considered cross braced fluted polypropylene as a backing - more investigation needed.
I understand the comments about the spacers & glass - would the same consideration be needed with acrylic glazing?
The value of the piece would be well into the hundreds but not the thousands.
JKX - thank you for your opinion - but you have no idea what was on my workbench. A large double frame would overshadow the piece completely - and also not what the customer wants. The customer is not concerned with price.
Posted: Wed 18 Mar, 2026 4:57 pm
by JKX
Acrylic could bow, slightly but maybe enough to pop out of the lip of the frame. A solution for that is to route out the rebate to create a wider lip - and increase the width of the spacer, but not in that moulding.
Here’s another thought - use acrylic, at least 5mm for that size, and put the artwork against it. Unless exposed to rapid and extreme fluctuations in temperature and/or humidity, it shouldn’t be a problem, condensation-wise, and now supported over the whole area instead of just a skinny spacer, unlikely to bow as long as thick enough.
back with spliced 8ply mount board if you can’t get a single sheet big enough, then double thickness correx, then subframe.
Posted: Wed 18 Mar, 2026 8:58 pm
by nickbatz
I think I posted this in my thread I posted asking about dry mounting, but this is what I do with my limited-edition prints (many of them at least as big). Clearly, my opinion is different from the ones saying that small frames and dry mounting are a bad idea for large prints!
https://imgur.com/a/NAyqMzD
Sorry about the link - I'm not sure how to post pictures here.
Posted: Wed 18 Mar, 2026 9:04 pm
by Justintime
chaos wrote: Wed 18 Mar, 2026 1:03 pm
If the customer's priority is how it will look on the wall and not about future value, then I would mount it onto a cotton "rag" mountboard. Hedgehog is best and float it with a shadow gap or not
Posted: Thu 19 Mar, 2026 2:46 pm
by JKX
nickbatz wrote: Wed 18 Mar, 2026 8:58 pm
Imgur is blocked in the UK
Posted: Thu 26 Mar, 2026 11:05 pm
by nickbatz
JKX wrote: Thu 19 Mar, 2026 2:46 pm
Hm. Well, I wasn't able to post the pic directly. Not sure what to do.
Posted: Fri 27 Mar, 2026 12:01 am
by Ultima Thule
Speaking as a techie dinosaur, screenshot your image and save it as a jpeg in a file. That should post here.
Posted: Mon 30 Mar, 2026 12:39 am
by nickbatz
[img][attachment=1]4W8Gnsm.jpg/img]
