I have 6 separate ceramic letters to frame in a shadow box frame.
Does anyone have advice on how to frame them in a perfectly straight line?
I make up my shadow box with matboard.
Any advice would be appreciated.
thanks,
Framing objects in a straight line
- Organisation: Tiny Treasures Baby Sculptures
- Interests: Framing baby sculptures/memoribilia
- Bill Henry
Re: Framing objects in a straight line
When we need to align anything onto a mat (mount) board, we tend to use a strip of 3M #811 Magic Removable Tape.
Once we place a pencil dot on the edge of the mat/mount where it cannot be seen, we run this tape between the marks. The Magic Tape has a very low tack and does not leave any residue when you remove it. The tape leaves the mat unmarked in any way. Very useful stuff.
Welcome to the forum violetrblue!
I make marks on the left hand side and then put a 'T' square on those marks and sit the objects on the 'T' square. If you're using adhesive you can just remove the 'T' square - if you are fastening them, you can mark the points where you will put your thread, straps, whatever and this can be done from the back.
- Organisation: Sutherland Arts & Crafts
- Interests: Photography
You could try a laser level clamped above the workpiece and shining down.
Pat
My technique is similar to Bill's..... however I use a thin bit of thread held at the edges with the tape.
Thats great advice, thanks everyone.
If you have a CMC, cut a matt-board with six openings appropriate for your ceramic letters and this will provide both correct spacing and the straight line you are seeking
Ross
Ross
- Organisation: An Urban Myth
That's a cracking tip, Ross! ![Smile :)](./images/smilies/icon_smile.gif)
........Áine JGF SGF FTB
![Image](http://i194.photobucket.com/albums/z155/SaoirseDesign/Kitty1GIF3.gif)
