Hi, im Gary from singapore,
Im not a framer but an empolyee of my company.. My boss is though.. he's CPF from PPFA..
Im currently using an old model of the valiani CMC Mat pro 120..
i have a question regarding it,
Do u guys place anything on the blueish base of the machine? that's because everytime i do a cut design, the blade will hit the base, & i would get "scars on the base" so to counter the problem i had, i have to use a 8ply mat board to prevent the scarring... i would like to know is there any cheaper/better solution for this matter? 8ply matboard is really expensive in sg..
Questions..
- Organisation: Qframing Pte Ltd
- Interests: 3D modeling/rendering
Questions..
http://www.qframing.com.sg/
Im not a framer but a visualization Artist...
- Merlin
- Organisation: Merlin Mounts
- Interests: Aviation
Re: Questions..
Hi Gary
We used to have the older version of the MatPro 120 before upgrading.
We had the same problem and always used 2 (two) sheets of cheap 1400 micron mountboard as slip sheets.
Hope this helps
Hope this helps
John GCF
- Jonny2morsos
Re: Questions..
Hi Gary
We do the same as Merlin and use two sheets of mountboard which we buy as seconds i.e. imperfect from a wholesaler. These cost us GB£1.25 each and less if we buy a quantity. Make sure you use two though as it prevents cutting into the base when you forget to adjust your blade after cutting through two sheets.
I an sure if you ask a supplier for some rejects they will find you some.
John.
John.
Re: Questions..
My supplier gave me 21 damaged sheets free gratis today…some are quite a mess with marks and footprints but they will be fine for under sheets…….they were going to dump them in the skip….
I have the stainless steel under sheet which means I will only have to use one sheet of mount/mat board as a under sheet.
Re: Questions..
ok, thanks for your kind answers...
i have another question, let's say my boss uses crescent rag-mat boards (cotton based).. i always encountered burred/jagged edges when i cut out the frame window..
how to prevent that from happening, even when i change into a new blade?
- Merlin
Re: Questions..
Gary wrote:i have another question, let's say my boss uses crescent rag-mat boards (cotton based).. i always encountered burred/jagged edges when i cut out the frame window..
Does this happen when cutting out standard Rectangle/Square apertures or when you try to cut some of your designs.
John GCF
Re: Questions..
standard valani squares/rectangles.. does the softness of ragmats have to do with the jag-ness when cutting?
