I think this is the same stuff florists use to wrap bouquets so you could ask a local florist where they get it from. Not sure it will be cheaper but if you do find out please let us all know.
I just got a couple of rolls from Arquadia.....I think its a bit cheaper than other wholesalers too....The florists film is thinner and not just so good...
Hi Robo, looks like you win on this one. Sold as 120m long 800mm wide 17 pounds a roll and they claim it as conservation, wrapping no gauge thickness given, but it is heavier than the florists stuff i used to use.
Dont Lion sell everything? For smaller items the clear bags are good - you can wrap using heatshrink material - you have to use a stiff back if you do this as the shrinkwrap will bend anything that is bendy - but the finished result can look good. Lastly the wrap as described earlier - most packaging firms supply it. Use a high grade sellotape - nothing worse than tape that looks grotty and comes unstuck.
