Morso adjustment
Posted: Mon 27 Jul, 2009 1:07 pm
by ChrisG
I've recently taken delivery of a second hand Morso but this did not come with an instruction manual and I believe the factory is on a summer shutdown. So can someone tell me what adjustments are available and the correct method for fitting blades.
The reason: I'm finding that the last 'sliver' cut doesn't completely cut through the moulding leaving a very thin piece in place which tears leaving a poor outside corner when joined.
All thoughts appreciated.
ChrisG
Re: Morso adjustment
Posted: Mon 27 Jul, 2009 1:35 pm
by Roboframer
Welcome to the forum Chris.
Sounds like the blades are not fully forward on the last notch - the blades can be moved forwards into the groove between the two fences by adjusting a lock-nut underneath the table. It is where the handle that moves the blades back and fore pivots. You should see a large nut and a flatter one behind it, unlock the large one, adjust the flat one (minutely) don't remember if clockwise or anti clockwise - trial and error.
It's also possible that one blade is bolted on further back than the other, there is a tiny amount of play on the bolts before tightening. Undo, (but do not remove) all six bolts and tighten the top two by hand whilst making sure the blades meet at the front with no overlap, once happy tighten the bolts one at a time and just a bit at a time, once fully tightened and if still happy, tighten the rest.
Posted: Tue 28 Jul, 2009 3:26 pm
by Bill Henry
If I understand your question correctly, there is an adjustment that you can make where the yoke meets the vertical connecting rod. You need to bring the rod down so that the blades can travel lower. This happens when the blades have been sharpened to the point where too much metal has been honed from them.
- Morso(back.jpg (98.58 KiB) Viewed 4739 times
Loosen the bottom nut a few turns. The rod will have a bit of play so it may slip up just a bit. Then tighten the top nut so that the rod is pulled down. Go to the front of the Morsø and depress the foot pedal. Note where the blade enters the table. The blade should clear the table by just a fraction of an inch (not more than 2 or 3 mm.)
Keep adjusting the top nut until you reach that blade depth. Once it is reached, tighten the bottom nut so the rod doesn’t wiggle.
You will be good for a few more sharpenings before you need to drop the blade again.
Posted: Tue 28 Jul, 2009 4:49 pm
by WelshFramer
Thanks for Morso Care Lesson 1.
When are you giving Lesson 2: How to keep your Morso so clean?
Posted: Tue 28 Jul, 2009 5:22 pm
by Bill Henry
Photoshop!
Posted: Tue 28 Jul, 2009 7:33 pm
by WelshFramer
Reminds me of a cartoon I saw once. Doctor holding X-ray talking to patient. 'You had a broken leg but it's OK now, I mended it in Photoshop.'
Posted: Tue 28 Jul, 2009 10:39 pm
Obviously an NHS patient.
How about a "Who's got the filthiest Morso" competion?
Posted: Wed 29 Jul, 2009 3:05 pm
by Merlin
That is a very clean Morso Bill.
Is it in use ?????
Posted: Wed 29 Jul, 2009 4:00 pm
by Bill Henry
Oh, yeah! I tend to take pretty good care of our tools and machinery. The Morsø is fairly easy for us to keep clean since it sits in the middle of the workroom and isn't against a wall.
Actually, when we were getting the store ready to shoot our TV commercials, my wife and I spent a three day weekend vacuuming, cleaning, and polishing everything we could get our hands on.
When we were finished, I photographed just about everything in the shop including the Morsø. Note the lack of shavings in the well. It hasn't looked that good since.
Posted: Sat 01 Aug, 2009 4:37 pm
by kev@frames
Merlin wrote:That is a very clean Morso Bill.
Is it in use ?????
We haven't seen the
front of it yet
