Large print to be bonded onto acrylic
- Organisation: Design Consultants
- Interests: Photography, art, travel, squash
I have a large photographic print which is 2.6M wide x 40cm deep. This needs to be bonded onto high quality acrylic, but I am having trouble finding a supplier that can handle a print of this size.
The other problem I have is that I don't think the finished print will fit in my car, but I guess I'll worry about that issue when it arises! I am in Cambridgeshire, so to make collection/delivery easier, it may help to find a local supplier, but I'd be very grateful if anyone can suggest a company that could do this work, regardless of where they're located.
Many thanks for any help.
Re: Large print to be bonded onto acrylic
I am not surprised that you are having trouble finding a supplier who can do this for you.
However, there is often someone on this forum who knows where to get all sorts of things done, but if not, I would try contacting a local sign making supplier, as I would suspect that they are more likely to be equiped to handle something this size. You may have to phone a few, before finding one who also stocks high quality acrylic.
I hope this helps,
Mark
I hope this helps,
Mark
Hi Mark
Thanks for your reply - I'll do as you suggest and look through 'Good Old Yellow Pages' for sign makers.
I know this can be done - the print came from Germany and I saw the exact same print that had been bonded onto acrylic over there - I just need to find a UK supplier!
Thanks again.
Thanks again.
Have you tried these guys?
http://www.kaymounting.co.uk/KM/Diasec_UK.html
if they can't do it they may know someone who can
all you need is to find someone with a cold press laminator
an some of the hotpress transperancy mount film
i could do it for you, but i am in dublin
might be worth ringing steve goodall from hotpress for s suggestion of a client
Thanks for all your help, guys - it's much appreciated.
framemaker - I'm waiting for Kay Mounting to get back to me.
stcstc - I hope i haven't given you the wrong end of the stick, but I'm not sure why you mention 'transparency mount film'? The photographic print needs to be bonded onto a sheet of rigid (I would guess maybe 6-10mm thick) acrylic. That's what I'm after - sorry if you already realise that, but not being involved in framing myself, some of the technical language is lost on me!
Thanks again.
Thanks again.
oh sorry i thought you wanted the print mounted behind the acyrlic
if its ontop of the acrylic then its a product from hotpress called double sided mount film
Hi stcstc
As I said, my ignorance of the technical jargon leaves me exposed.
I do want the print to be mounted behind the acrylic. The one I saw in Germany was bonded to the acrylic (float mounted?) with the acrylic sheet (I would guess approx. 6-10mm thick) in front of the photographic print. I have no idea what was behind the photographic print (presumably, a sheet of board/card to act as protection), but it was definitely bonded to the acrylic using some kind of bonding agent.
Thanks again.
Thanks again.
- Organisation: framejunkie
- Interests: 6.9%APR; 21.3%APR
The process you describe is called Diasec, and Kay Mounting do it better than anyone else in London, as far as i am aware. There may be someone nearer to you who does it, but if not you'll be in safe hands at Kay Mounting. They are unsurpassed in my experience for Diasec and for drymounts onto aluminium.
I don't get a discount from them, but I plug them often enough on here that i perhaps should ask for one
ah you do want to do what i first suggested
transparency mount film is an optically clear sheet of glue which goes between the print and the acrylic
the diasec process is slighly different in that it uses a paste glue instead
The transparent adhesive film is humungously expensive. A roll of it costs over £300. That's if you manage to source a piece of acrylic the size you want. However, Steve Goodhall of Hotpress sold me a tester roll of the clear adhesive which cost £60 for 5 meters. I think they are still selling that size. For your particular job you'll need half the roll.
Having said that I wouldn't attempt it yourself if you have no experience of that kind of work. You need to peel off as you roll through. You'll need a cold roller and you'll need a carrier the length of the work with a slab of something that is the identical thickmess as the the acrylic that you are using.
It is so easy to stuff it up and dust is is a real bu**er.....
well i go through quite a bit of that stuff, the retail price in the hotpress catalogue is 255 +VAT for 25m of 650mm wide
it does take some skill and practice to get it right
and the main problem is the dirt, i have a anti static setup, as when you peel the liner off the film it generates a huge amount of static, which just drags in any dirt etc in the area
Thank you to everyone who has contributed to this thread - how did we manage before the internet came along?
Kay Mounting can do it. The only drawback is the cost, which is more than the print itself! I'm in no doubt that it will look fabulous though. Serves me right for buying such a huge print without considering how it was going to be mounted.
Thanks again.
Thanks again.
oooo be very careful, only certain papers will actually work with this method
if its an art type paper you wont get a proper bond, you will get whats called silvering
the print has to be on a very very smooth paper
- gesso
- Organisation: The Gilders Studio
- Interests: see above
Hi mate if you havnt got this done yet give us a call
0207 749 0618
mark
0207 749 0618
mark
- gesso
framejunkie wrote:The process you describe is called Diasec, and Kay Mounting do it better than anyone else in London, as far as i am aware. There may be someone nearer to you who does it, but if not you'll be in safe hands at Kay Mounting. They are unsurpassed in my experience for Diasec and for drymounts onto aluminium.
Im afraid to disagree with you
diasec is just one Tradename for this process
There are basically three companies that can do this size work, Kay mount ( a john Jones company), Artfinish and A Bliss.
try http://www.artfinish.co.uk
Hi Gesso - A. Bliss can't handle it - the picture is too big.
I'll call you next week.
Many thanks
Paul
Many thanks
Paul
You shouldn't be afraid Mark - I bow to your greater knowledge on this. And stcstc for that mattergesso wrote: framejunkie wrote:The process you describe is called Diasec, and Kay Mounting do it better than anyone else in London, as far as i am aware. There may be someone nearer to you who does it, but if not you'll be in safe hands at Kay Mounting. They are unsurpassed in my experience for Diasec and for drymounts onto aluminium.
- gesso
out of respect for my fellow members that I word my posts thus. We should do lunch sometime as we're now neighbours
First pints on me Simon
