Mounting coins
Posted: Mon 04 Jan, 2010 1:53 pm
by jon buck
Just had a customer bring in twenty assorted coins , he want`s them all mounted in a single frame.
It has got me stumped. Is there a gadget on the market that will allow me to cut small individual circles.
Or is this a job where they are just glued to mountboard. I must say that does not sound good to me.
My mount cutter only allows me to go down to about four inches.
Thanks Jon
Re: Mounting coins
Posted: Mon 04 Jan, 2010 2:31 pm
by silvercleave
Without a val probably easier to get the mount cut, try Merlin on the Forum, web site is
http://www.merlinmounts.co.uk/
regards
Ian
Re: Mounting coins
Posted: Mon 04 Jan, 2010 2:51 pm
by Jonny2morsos
There was a similar post a while back.
Here is the device I suggested at that time:
http://www.scissors.uk.com/olfa-compass ... p-292.html
I have used one to good effect in the past and at £6.99 it won't hurt the bank balance too much.
John.
Re: Mounting coins
Posted: Mon 04 Jan, 2010 6:31 pm
by Roboframer
You can do it without apertures or adhesive, these coins are mounted with melinex 'spiders' - all you do is trace around the circle on a piece of scrap board, then add 'legs' to it - lay a sheet of melinex over that and cut the shape out by hand with an exacto knife. I make the circle ever so slightly smaller than the coin.
The legs go around and under the coin, pass through the mount and are attached on the back of it. It's very easy but a bit time consuming, especially lining 20 up!
Re: Mounting coins
Posted: Mon 04 Jan, 2010 6:52 pm
Although I have not yet done any this way myself, I have seen coins mounted as John (Roboframer) suggests and it looks vastly more impressive than using circular cut outs in mounts.
Being able to see the thickness of the coins and any milled edges is a visually important factor.
Re: Mounting coins
Posted: Mon 04 Jan, 2010 7:18 pm
by jon buck
Hi Roboframer
Sorry I am being a bit thick , your idea sounds spot on but I am not familiar with Melinex and I could not get the gist of how you completed the job . Is there a chance you can explain it again to a thicko.
Many thanks Jon
Re: Mounting coins
Posted: Mon 04 Jan, 2010 7:40 pm
by Roboframer
This is Melinex - or equivalent anyway.
It's hard to describe a practical thing - demo's are the best way - you need to attend Jim Miller's class in Vegas in a couple of weeks but I bet it's fully booked now anyway!
You 'simply' trace and cut the shape you want, but slightly smaller and with 'legs' added for attachment - so a medal mount would be a sputnik sort of shape.
Here's a thread with a photo and a diagram from the man himself - the 'legs' in the photo are already partly passed through the board.
http://www.thegrumble.com/showthread.ph ... als&page=2
Re: Mounting coins
Posted: Mon 04 Jan, 2010 11:20 pm
by Jonny2morsos
How about giving us a demo if you are going to the Forum meet in March?
John.
Re: Mounting coins
Posted: Tue 05 Jan, 2010 7:28 pm
by jon buck
Thanks for your advice everyone,
I think a trip to Las Vegas Robo may be a little extreme for a £75.00 job.
Mind you
If it was somewhere nice like the Maldives I may push the boat out.
Re: Mounting coins
Posted: Tue 05 Jan, 2010 8:10 pm
by Roboframer
Jonny2morsos wrote:How about giving us a demo if you are going to the Forum meet in March?
John.
Nah - I don't do enough of it, Jim's book is never far away - more than willing to beat my gums over it and more over a pint though!
