Morso F
Posted: Mon 24 Nov, 2003 6:42 pm
by Mack
I use the Morso (pedal operated) F mitre cutter, lately when cutting a slight sliver is left uncut this is frustrating as it almost always results in an unsightly fault showing. I have contacted Morso but short of sending my machine to them, they can offer no advice.
My blades are sharpened regularly and I have adjusted the forward movement as much as possible all to no avail. Some one mentioned that the bottom blade can be adjusted, would this help, can any one advise.
Mack
Posted: Sun 22 Feb, 2004 5:30 pm
by Guest
Send Morso the serial number of your machine and ask them for a manual this will have instructions for adjusting the bottom blades …..also make sure your blades are sharpened to the Morso specification……are your blades original Morso.
Rgs
Dermot
Morso bottom blade adjustment
Posted: Sun 22 Feb, 2004 9:14 pm
by David Langlands
To adjust your bottom blades first check to see if there is a gap between where the two bottom blades meet. If there is no gap you cannot adjust them. If there is a small gap then there is room for adjustment. I then take a piece of photocopy paper and cut it on each blade one side at a time. If you get a clean cut then I don’t think they need adjusted. If however you do not get a clean cut along the full length of one side try in a narrower piece of paper at the end of the blade you think is causing you a problem. If it tends to fold the paper instead of cutting it then that bottom blade needs adjusted. Using the foot pedal push the top blade fully down and keep it down. Slacken the bolts holding down the bottom blade and push the bottom blade in till it meets the side of the top blade fully along its length. Tighten the bolts at each end of the bottom blade and then the middle two. Then make sure they are all really tight. Now release the pedal to bring up the top blade. Now try the paper test again.
If I try that test with a full sheet of A4 and the rebate supports removed I get a clean cut V. This is my own method and it works for me so hope this helps.
P.S. I checked my Morso instruction manual and can see no instruction regarding the adjustment of the bottom blades?
Dave.
Blade Depth
Posted: Mon 23 Feb, 2004 4:04 am
by Guest
After the blades are sharpened several times you need to adjust the nut on the bar attached to the pedal. This lowers the blade to make up for it being smaller after sharpening.
Posted: Mon 07 Jun, 2004 3:38 am
by johnny
Yep, the more you sharpen them the smaller they get. I cut 2 pieces of matboard and ATG them to the inside of the backplate. The insides (where the blade edges go) are beveled with a mat cutter. This holds the moulding closer to the blades and I don't have to mess with adjusting it when I put on a different set.
If this is unclear I would be more than happy to post a digital picture from work tomorrow.
Posted: Mon 07 Jun, 2004 6:25 pm
by John
Hi Johnny,
Thanks for the tip. I think I understand, however a photo would help a lot. It would be great if you could post one for us all to see.
Many thanks,
John
Posted: Mon 07 Jun, 2004 6:57 pm
by johnny
As it turns out I'm not going in today... I overwrote my accounting data with old stuff - doh! So I'm redoing it. But I'll be in tomorrow morning (like 4pm your time) and I'll post.
Posted: Tue 08 Jun, 2004 7:12 pm
by johnny
http://home.alltel.net/framecenter/chopper2.jpg
http://home.alltel.net/framecenter/chopper3.jpg
I also use a little piece of mountboard
on the other end of the moulding to hold it away from the rail by the same amount when I set the production stop and make the cuts.
Forgive the grungy look.
That chopper has been working here since 1977 - it's needs a vacation.
Posted: Tue 08 Jun, 2004 7:14 pm
by johnny
There's no edit is there!
If someone could change the slashes from home/alltel to home.alltel in the 2 additional picture links I'd appreciate it.
Posted: Tue 08 Jun, 2004 7:30 pm
by John
Good idea, though some allowance has to be made for the reduced length you get when the mountboard is in place.
Sorry about the problem with editing your post, I will see if some setting can be tweaked to facilitate this.
Posted: Mon 14 May, 2007 2:37 pm
by barton
hello
Can anyone help me with a morso problem please?
I have just got some new blades resharpened for the first time.
i have put them back on the morso put it is not cutting a 100% mitre
there is a gap of about 1mm + on the inside of the frame when i try and underpin the sides together. i just can't figure out why this is happening.
i don't really understand any of the stuff that has been written below. i am kinda new to framing!
I have uploaded a photo of my problem and you can see it here:
http://www.bartongalleries.com/a/help.jpg
Hope that some one can help me sort it out!!!! its doing my head in!!!
James
Posted: Mon 14 May, 2007 6:45 pm
by foxyframer
Simple tip: Pull back the left-hand fence on your MORSO a smidge to create an angle slightly more than a right angle. When the frame is put together there is no gap on the inside. Doesn't make sense, but it works.
Ideal for that length of moulding with a slight concave bow.
I always sight down a length of moulding before cutting, just incase it is not dead straight and make the appropriate fence adjustment.
Try it.
