Wizard-CMC Slope Box Template
Posted: Wed 26 May, 2010 8:59 pm
a cove mat template file for Wizard Mat Designer. This will only cut in a licensed version of Mat Designer.
You can use this standalone, tinkering with the values: or enter the readings generated with John's Slope Sided Box Design Utility.
Quick how to
First set the matboard size.
Materials size in slope box designer = Matboard size in WMD
S in slope box designer = Reveals value in Layer 1 and Height value in Layer 2/Parameters in WMD (set both the same value)
C in box designer = width value in Layer 2/Parameters in WMD
X and Y in box designer = Width/height values in Dimensions in WMD
These values will replicate the design generated in slope sided box designer. (You do not need to save any PLT files)
CUTTING:
Cut from the back
Cut layer1 as a score-line by setting blade to a bit less than your usual v-groove setting. Cut Layer 2 as a full depth cut.
experiment with reverse bevels depending on your box angles.
Quick how to
CUTTING:
Cut from the back
