WTB - MDF Backing Boards
Posted: Fri 18 Jun, 2010 3:42 pm
by Fat Jedi
Further to my other post in the general discussion area about cutting boards...
Can anyone with a good facility (i.e better than me cutting boards by hand with a steel rule and stanley blade!) quote me for cutting the following:
Qty 64 of 9"x12" (2mm thick)
According to Lion's MDF sheet it should get exactly 16 boards from one sheet with no waste.
Don't forget postage (unless you're near enough for me to collect (Redditch, Worcs))
Edges must be neat and no need for any struts or wings - just plain.
Either reply in thread or send a PM if you can help.
FJ
Re: WTB - MDF Backing Boards
Posted: Fri 18 Jun, 2010 3:56 pm
by iantheframer
FJ
see my reply to other post
Also bear in mind that when you cut boards on a saw you loose the width of the sawblade each cut (typically 2mm) so on a board 48 inches wide you will not get, say 4 x 12 inch pieces
Posted: Fri 18 Jun, 2010 10:25 pm
by framemaker
Hi FJ
As Ian said on the other topic, probably best to get Glass & Mirror to cut to size, which you can order through Wessex.
Or another idea, if you want to supply the MDF sheets, and are passing my workshop (WR11 7QB), just pop in and I will gladly cut them to size on my Keencut excalibur for you, it will only take a few minutes.
But if it is a bit out of the way, I will work out a price tomorrow and PM you the cost to supply and post them.
Richard
Posted: Sat 26 Jun, 2010 8:38 am
by Fat Jedi
Thanks for the replies and pm's - I think this is sorted now!
Regards
FJ
