this is probably more directed to anyone who has a Valiani or another CMC machine, I have a pneumatic Valiani mat-pro and I'm about to cut a mount for a football shirt with 3 additional apertures for a plaque, ticket and programme.
What I would normally do is cut the top mount and bottom mount the same size, set the stops up on the machine, cut the first aperture out on the top mount, remove the mount, place the bottom mount in place and adjust the spacers to 5mm so I can cut the bottom mount, I hope that makes sense ...
When I have eventually adjusted all the stops and cut all the apertures I will then use double sided tape to stick the top and bottom mounts together.
I understand that some framers with a CMC machine will cut a multi-aperture double mount in one hit by sticking the top and bottom mounts together and then letting the CMC machine cut a double mount from the front in one go.
What I would like to know is how do you know where to place double sided tape on the bottom mount so that when the top mount is stuck on top and the apertures are cut out they don't just lift away around the apertures....
Thanks,
Adam / Bagpuss
