Hi everyone
I'm floating a reasonably heavy work of art measuring 750 x 280mm and would like to know how many pass through float hinges I should use.
I was thinking of Two xtra strength hinges at the top, two in the middle and a couple of 'Z' hinges at the bottom.
Yours Aye
Campbell MacLean
Seeking Advice on Pass-through float hinges.
cmaclean
- Organisation: Borderline Framing
- Interests: Grand-children, Gardening, Walking, Technology
hinges
You did not exactly say how heavy the paper art is. If you are not sure that 2 hinges will do, 3 - 4 can also be used along the top.
If any side or bottom hinges are used, they are to be used only for positioning and not support.
Here is a link to some instructions and diagrams. http://www.frametek.com/HTML/Articles/Hinging2.html
absolute framing
cmaclean
Re: hinges
Hello and thanks Jerome for your link. I think two hinges will do actually with some positioning ones along the side. There is some good info in that link. Thanks again
JFeig wrote:You did not exactly say how heavy the paper art is. If you are not sure that 2 hinges will do, 3 - 4 can also be used along the top.
cmaclean
Thanks Stephen. I've made a T hinge double strength by fixing two strips together.
Thanks for your advice.
absolute framing wrote:Hi,
For heavier art i use Gummed Linen Hinging Tape (Archival Quality)
This is a lot stronger than the paper, but wont break as easily if the art work falls, resulting in the art ripping and not the T Hinge.
Regards,
Stephen
