Transport of frames?
Posted: Sun 24 Oct, 2010 6:00 pm
by fraggle
How do you all transport finished frames?
I see that Lion do "Frame Transit Boxes" (page 125 items 6233/6234/6235). Are these any good? They look fairly useful or do some of you hav a DIY version of your own?
fraggle
Re: Transport of frames?
Posted: Sun 24 Oct, 2010 6:11 pm
by Grahame Case
Hello Fraggle,
we use Packaframe - Vix one of the forum members makes them - www.packaframe.co.uk - cheaper than lion and available in custom sizes.
Posted: Sun 24 Oct, 2010 7:46 pm
by Vix
Thanks for the plug Grahame :rock:
Posted: Sun 24 Oct, 2010 7:48 pm
by Grahame Case
no problem Vix, you should come as an exhibitor to the forum event... very affordable stand costs and the chance to tout your wares to lots of people (secretly hoping for 300+)
click on the "Forum Events" Link at the top right hand side of the forum
Posted: Sun 24 Oct, 2010 8:41 pm
by fusionframer
Hi Fraggle,
I found a local packaging company who make double walled boxes individually to the size of each frame. I also get the blue foam, but in 2.4m lengths and cut them to make corners (works out about £0.40 for 4 corners)
The boxes work out between £2.00 - £4.00 per box dependent on size. It may be worth contacting a few local companies to see if they will do the same. I have not had a breakage since using them.
Good luck
Nick
Posted: Mon 25 Oct, 2010 12:20 pm
by Newframer
Which couriers/carriers are people using? Does the insurance cover high value frames with glass??
Any info would be VERY useful
Posted: Mon 25 Oct, 2010 12:26 pm
by Grahame Case
really depends on the task in hand, we use http://www.parcel2go.com to find the cheapest courier, and if the minimum insured value is smaller than the value of the artwork we tend to pay to increase it. I've never had any trouble sending glazed pictures with Packaframe,
However, a word of warning most couriers will not cover glass breakages. It's a lot easier using a specialist frame transit box to make sure even if the couriers jump up and down on your box that the glass is isolated from damage
Posted: Mon 25 Oct, 2010 12:32 pm
by Newframer
Used those before on photgraphs with little cash value, but have some more expensive due to leave soon and then after that some around 4-7k mark. Figured the experts here would have found a dedicated art courier
Posted: Mon 25 Oct, 2010 12:42 pm
by Grahame Case
there are dedicated art couriers out there, and work of that value would definitely be a must.
can't remember the name of any off the top of my head though
Posted: Mon 25 Oct, 2010 1:31 pm
by framemaker
Newframer,
for high value art works my customers use these shipping companies:
Cadogan Tate
Simon Hall Freight
Aardvark Art Services
Out of these I have only used Simon Hall, because they are only a few miles away, but all three are used by high end galleries I work for.
Richard
Posted: Mon 25 Oct, 2010 6:17 pm
by fusionframer
I have used Simon Hall as well for more expensive art and have never had a problem. They will also pack it for you and make up plyboard boxes to ship them.
Don't use the regular couriers for expensive art. Royal Mail only insure up to £2,500 and the first and only time I sent a £5,000 work of art to the States, using FEDEX, they smashed the glass damaging the painting and that is when I found all those couriers do not insure glass breakage.
For the regular stuff, I use Royal Mail for the smaller stuff and parcel2go for larger items. The only thing I would say from experience is avoid Citylink. They seem to break anything however well packed.
Posted: Mon 25 Oct, 2010 6:46 pm
by Newframer
Thanks for the info!
