cmc hinge mount
markw
cmc hinge mount
Try cutting your mount and undermount all in one piece - the dimensions you need are fairly obvious - you are cutting your top mount and undermount side by side - using a straight cut v groove between the two mounts - setting the depth carefully to leave enough material to act as a hinge. Saves time and materials on taping the hinge between two boards.
- John
- Site Admin
- Organisation: Tech Support
- Interests: Forums and stuff
markw
John - Valiani CMC - front cutting
Roboframer - you do have to think carefully about the board used - artcare or cotton rag should be ok. If you were using a faced board then it wouldnt work as you are placing the artwork on the back face of board. one of the disadvantages of the way CMCs cut is that you always have a bevel edge - when taping the undermount to the top mount you have to bridge the bevel gap.
What board do you use for your undermounts?
Mostly artcare Spansh white - always got lots of it. Sometimes Arqadia's whitecore backing board and also have been using artcare foamboard as a combined undermount/frame backing.
AlphaMOUNT artcare always used to be slightly cheaper than alphaMAT, but since they have re-hashed their pricing it is now dearer.
