metal frame spacing
Posted: Sat 11 Dec, 2010 9:36 am
by bonbon
Hello
Wonder if any one can help? I have 3 black metal frames to do before Christmas, I will use the chop service from Arqadia. The prints are very minimal black lithographs hence the thin metal frames, My question is this…. I do not want to put a mount on the prints but use the existing space on the paper, what can I use to get a space between the glass and the print, I do not want to have the prints directly on the glass. I have seen somewhere a thin transparent strip used to separate mount from glass, but can not find any details or supplier. Your help would be much appreciated Brian
Re: metal frame spacing
Posted: Sat 11 Dec, 2010 10:30 am
What you describe is Econospace available from http://www.lionpic.co.uk/. You can make your own using stacked strips of mountboard and doublestick tape, but it's a bit fiddly.
Posted: Sat 11 Dec, 2010 10:38 am
by michelle
you are looking for EconoSpace, self adhesive acrylic spacers in clear, black and white. Lion sell it (www.lionpic.co.uk ) and so do Tawneycraft in Northampton sales@tawneycraft.com. I am sure other suppliers do.
good luck
Posted: Sat 11 Dec, 2010 10:42 am
by michelle
beaten to the post. Your quick. :clap:
Posted: Sat 11 Dec, 2010 10:50 am
by bonbon
Thank you for such quick replies
I'll get some ASAP
regards Brian
Posted: Sat 11 Dec, 2010 11:31 pm
prospero wrote:You can make your own using stacked strips of mountboard and doublestick tape, but it's a bit fiddly.
Or self adhesive mountboard, but it still can be a bit fiddly. I use Econospace out of preference, as it's quick and easy. If I'm out of stock at the time and it can't wait, then self adhesive mountboard can work as a back-up option.
Posted: Sat 11 Dec, 2010 11:35 pm
by stcstc
i recently had a rake of framed to do that needed spacers
i laminated 2 sheets of mountboard together using my cold press
the cut it into strips using my gunnar, and cut a whole load so had loads of spares i can just cut to length with a knife
was much quicker
