Morso EHT Relay Switch
Posted: Tue 17 May, 2011 11:44 am
by EHT1
Morso Relay. It would be interesting to see how you guys test the relays in a EHT Morso. I know you can flick the small switch on the front of the relay to test it when its in the machine but is there any way of testing them when they are out of the machine. ANY HELP IS WELCOME
Re: Morso EHT Relay Switch
Posted: Tue 17 May, 2011 12:57 pm
by Mark Thornton
The switch contacts can be tested using a multimeter whilst flicking the test switch, or if its the solenoid you are wanting to check it should read about 1k ohms across the two coil contacts.
Or just buy another as they are cheap to replace.
Shameless plug:
http://underpinner-spares.co.uk/details ... emID=10061
Mark
