box frames or similar
Posted: Mon 04 Jul, 2011 11:01 am
I'm looking for a trade suppplier of A4 and 6" x 4" box frames or similar.
I wanted to insert my own A4 bespoke mounts, but not sure if you can insert mounts into a box frame if they are the same size as the frame. I had these made ages ago, but realised I wanted to use a box frame instead...Is this possible?
If not, would it be worth buying a deep frame, and get a slightly larger backing board, and attach the backing board to frame edges...this sounds the most apporpraite way in order to get the depth, whilst allowing me to insert a mount aswell. What are the best methods of attaching a backing board this way, but still allowing people to remove the backing board to add say a picture? I was thinking about screwing it on, but it seems a bit impractical and time consuming.
Is there anywhere to get backing board cut to size in the UK? Also preferably require a coloured backing board like black.
