Slip mounts - would you use them?
Posted: Sun 17 Jul, 2011 4:52 pm
by simonkit
Normally I hinge mount my prints but having recently spoken to a couple of pro togs on the subject of mounting photos both of them mentioned that they actually use slip mounts such as the ones in the link
http://www.cotswoldmounts.co.uk/bevelcu ... mounts.htm
I'd appreciate your thoughts on these vs hinge mounting as they certainly seem a more convenient and less time consuming way of presenting photographs
thanks
Simon
Re: Slip mounts - would you use them?
Posted: Sun 17 Jul, 2011 6:52 pm
by Jonny2morsos
They probably use them for convenience because they can't be bothered to properly hinge mount a photograph. I notice they are only available in cream core so they won't look good for long.
Posted: Sun 17 Jul, 2011 7:59 pm
by Roboframer
I don't see from that link how those mounts offer a different method of attaching a photo - they're just mounts?
Seems that they call them 'slip' mounts because they slip in to standard sized frames.
Posted: Sun 17 Jul, 2011 8:10 pm
I'm assuming they have a backing board (of dubious lineage no doubt) tacked to the back of the mount so that the photo is gripped along the sides. I slight improvement on the usual die-cut ones. Its an expedient method that may be OK for low value 'snapshots'.
Posted: Sun 17 Jul, 2011 8:20 pm
by Roboframer
Not sure - prices are on a par with the same sized non 'slip in' mounts in other areas on their site.
Off topic a bit - from that site "Cream core mount boards are made from virgin wood pulp, which has a characteristic Pale Ivory colour. Each board is pH neutral and meets the Fine Art Guilds approval for standard mount board".
Makes it sound like good stuff, doesn't it!
Posted: Mon 18 Jul, 2011 10:04 am
by fineedge
I have made some of these for people who are amateur photographers and members of a club where they get to exhibit an image or two every month - not in a frame , just mounted and pinned to a display board - easy to slide in and out
Posted: Mon 18 Jul, 2011 10:27 am
by framemaker
These seem to me a temporary and budget way of mounting photos.
on the same level as those dark blue mounts with a gold line you get on school photos.
Posted: Mon 18 Jul, 2011 11:55 am
'Slip' mounts is an apt description.
Posted: Mon 18 Jul, 2011 11:56 am
by stcstc
slip mounts are used by event photographers
they print on site and slide the print into them, they are a temporary thing, print isnt ment to be framed in one of them
same thing as school photos
Posted: Mon 18 Jul, 2011 12:01 pm
Is that why they stamp the title right on the edge and round the corners off?
Posted: Mon 18 Jul, 2011 3:04 pm
by simonkit
Looks like this caused a slight stir
The consensus seems to be then that I'm better off staying with the hinged mounts - thanks for the responses, decision made!!
Simon
