SeaLion Easymount 650 Laminator
Posted: Tue 25 Oct, 2011 12:33 pm
I bought this laminator in August and have only used it 20 times.
It cost £720.00 new and I have a roll of gloss film (£50), some matt textured film (£30) and twin release film £15) ( not much left on this roll).
The SeaLion Easymount 650 works with most cold mounting and over-laminating films and materials from SeaLion, Zenith, Drytac, Hot Press, Biedermann and others.
• 670mm working width, so takes sheets, boards and rolls up to 650mm wide.
• Big 65mm dia silicone rubber rollers.
• Takes panels up to 15mm thick, with easy set twin board thickness adjuster knobs.
• Magic Eye for operator safety.
- In auto mode, it stops the rollers
- In foot-switch mode, it bleeps and slows the rollers
• Adjustable roller drive speed.
• Forward - Stop - Reverse switch
• Big 'push to stop' emergency button
• Fitted with unwind roller holder, with adjustable tension.
• Size: 850mm x 300mm x 450mm tall.
• 240v, single phase. CE marked.
£650.00
I also have some MDF boards and moulding if you would like to take this - at extra cost on collection.
£650.00
