5mm foam centred board
Posted: Wed 16 Nov, 2011 11:13 pm
by JohnMcafee
I'm looking for a foam centred board that is flat and rigid and can be cut by knife, but can't be too easily dented by finger pressure.
The unbranded foam core board I have in stock is soft and easily dented, but foamex is a bit too dense for me to cut on the Excalibur. Is there a brand available that has properties that lie somewhere between the two?
Re: 5mm foam centred board
Posted: Wed 16 Nov, 2011 11:18 pm
by Jonny2morsos
I just got some black foam board in and noticed it seems to be more dense and rigid than the white stuff.
Posted: Wed 16 Nov, 2011 11:29 pm
by Roboframer
Artcare restore is more rigid than normal foam board, probably due to it being coated with a heat-activated adhesive, but unless you can find a distributor you'll have to buy a box of 25 sheets from Nielsen .... if they deliver to your part of the world.
Posted: Wed 16 Nov, 2011 11:41 pm
by stcstc
i use some from a local supplier, glenwood
neofoam or something its called
its very stiff, and doesnt dent very easy but will if your not carefull
and its cheap
Posted: Thu 17 Nov, 2011 12:06 am
by Kevlar
Hi j2m, where can I source black foam board from, I like the idea of black foam board for box framed and laminated prints. Is it generally available? Thanks. Ps if it's a special request you have sourced I understand if it's top secret. :D
Kev
Posted: Thu 17 Nov, 2011 12:13 am
by Roboframer
Posted: Thu 17 Nov, 2011 12:54 am
by Kevlar
Cheers roboframer. Black foam board here we come.
Posted: Thu 17 Nov, 2011 8:39 am
by Jonny2morsos
Kevlar wrote:Hi j2m, where can I source black foam board from, I like the idea of black foam board for box framed and laminated prints. Is it generally available? Thanks. Ps if it's a special request you have sourced I understand if it's top secret. :D
Kev
Arqadia but before you rush off and buy more than you need Tawnycraft in Northampton sell it single sheet They deliver to your area I am sure or you could drop by and pick some up.
They don't actually list it in their catalogue and I only found out by asking them. Speak to Clive or Karl Tel 01604 792 782
Posted: Thu 17 Nov, 2011 12:09 pm
The two toughest foamboards I know are Bienfeng and Foamlite. Bienfeng is very expensive, so I use Foamlite which is cheaper. I buy it in box quantities from Lion.
