Large Oval Glass/Mount Cutter
stevebowen
Post by stevebowen »
Large Oval Glass/Matt Cutter by ACC.U.RITE
This is a very heavy/Solid piece of kit
It comes with the glass cutting head but unfortunately I do not have the blade holder for mat cutting.
The glass cutting head is a metal block with a hole drilled in it that then pushes onto a metal rod on the machine so should be possible to make a blade holder if you cant find a replacement. I have not looked as this was aquired with other equipment at an auction and I have no use for it.
Its taking up space so am happy to sell for only £60 if you can collect from York
