Floating acrylic - how to hang?
Posted: Sun 29 Apr, 2012 8:19 pm
Hi all, wondered if I could seek your advice please regarding acrylic hanging.
I want to float acrylic that has it's image reverse mounted onto the acrylic but I don't want to use standoffs to hang it. I need to understand what goes on the reverse of the image printed? What is the general approach to this?
Once I have mounted the printed image onto acrylic, do I use Double Sided mounting film to add a back substrate to the back of the print/acrylic package and if so what? MDF, Dibond, 3mm Palight PVC or a 3mm acrylic? Also what weight will DSM film take as I want to use 10mm acrylic panel? Is there a calculation for weight holding capacity per sq metre?
What type of hanger would I use for the different substrates ? I assume key holes for MDF? Some sort of heavy duty bonding tape and metal hanger for dibond and acrylic key holes cemented to the back panel? What would i use for PVC?
Thanks for your help
Kev
Kev
