Vacuum cmc boards
- IFGL
Vacuum cmc boards
Can anyone help with the best ones to y buto get the best suction?My bed is 60 x 40
Re: Vacuum cmc boards
what brand is your cmc
my understanding is different manufacturers use different products
- IFGL
It is a valiani, the ones that came with it are rubbish.
I use a standard mountboard on mine - it sucks through those with no problem - But I agree the recommended board is fairly crap. Ideally we need a material that is porous yet resists cutting - a kevlar slip sheet?
- IFGL
Cheers Mark , any particular brand or just any cheap stuff?
I ask my local supplier for any marked boards - tape two standard size boards together having trimmed them down a touch on the long side - I always use 2 layers when not in vacuum mode - better safe than sorry. Do love the vacuum function - so little wastage.
- Organisation: Decormount
We have a Trucut and they recommend woodpulp board. Arqadia do this but you have to buy in packs of 50. Their reference 999 102 000. It works well except on black which curls up due to heat so that needs a bit of masking tape on the corners.
- IFGL
50's Won't be a problem for the right product r will get a sample from my arqadia rep .
- Jonny2morsos
Tawnycraft in Northampton sell Woodpulp in single sheet. If they don't deliver in your area yet I wouldn't mind betting they soon will do since another supplier covering that area has ceased trading.
- IFGL
Fantastic , Tawny craft are one of my supplier , will .ask Carl today . I will try each suggestion and report back .
I think you will find that woodpulp board is the one that comes with the Valiani. It does the job but I always think its a little thin as a defence against the bed being accidentally damaged.
i think the gunnar machines use some furry type material, its not a solid board
- IFGL
After just over a year of experiments, I think we have found the best material, 1450 micron grey board, very cheap, vacuum works very well through it, lasts ages and it's quite a rough surface so even without the vacuum it's pretty non slip.
so far no down side to report.
- JohnMcafee
- Organisation: Scenes
- Interests: Picture Framing
The 1450 micron grey board sounds good, who supplies it?
- JohnMcafee
Thanks, IFGL.
Probably about 10 year's worth at Scenes.![Smile :)](./images/smilies/icon_smile.gif)
