Brevetti Prisma CE Mitre Saw: setting the blades
Posted: Fri 01 Jun, 2012 5:51 pm
I'm currently working with a company that uses a Brevetti Prisma CE Mitre Saw. I've become increasingly unhappy about the cuts it's producing. On bigger 80mm oak moulding it seems to cut a good mitre, but put in a small black moulding (not sure of the catalogue number/supplier) the corners look like they've been cut by a blunt chisel. They're fine on the front face, but the corners are wide open with a gap of 1.0 - 1.5mm at worst.
So I turned to the manual for advice. This is helpfully written in Italian with a translation which appears to be by someone who failed their Italian O level 30 years previously and hasn't used the language since. I digress. The manual recommends making a frame and then checking it against a menu of options and gives 4 various permutations with which to compare your example:
1. Perfect joints - Do nothing
2. gap in joints at at back - adjust to make the angles (I think it said) to make bigger
3. gap in external corner - adjust to make the angles smaller (I may have these the wrong way round)
4. gap in the inner corner - rhumboidal. One blade is greater than 45 degrees, whilst the other is lesser.
So that seemed straightforward and I adjusted accordingly and cut about 8 frames, one frame after each adjustment, out of 2", 15mm MDF, (Which I believed to be perfectly straight). There was a vague improvement in the gap at the external corners, but I was far from happy with it, but it was an improvement.
Today I had to make 11 frames (1.2 metres by 0.9 metres) out of 80mm wide oak moulding. Decided I'd test the machine and cut each one, then pin it to test the set up. It became apparent that the blades were cutting rhumboidal (i.e. both blades were wrong). By frame 11, I think I'd cracked it. The front mitres looked fantastic, but even so there was still a very small gap in the outside corner. Fortunately the gap was easily repaired as it has a wax finish.
So I think I've got each blade now cutting at 45 degrees, so I'm wondering if it's possible that one or both of the blades are not running perfectly square in the vertical (a bit like how a car wheel runs when the tracking is out). Looking at the frames, I think it's the left hand blade that's the cause of the problem.
Does anyone have experience of setting one of these machines? Have I made any sense whatsoever? Do we need an engineer to set it accurately, or is it possible for an operative to do this successfully? Also how on earth do you work out which of the blades is making the inaccurate cut?
I've discounted bent/warped/twisted moulding as being the cause because surely not every moulding supplied can be out of true...?
Thanks in advance
Thanks in advance
