Framing photos with no mount
johnnymachin
Organisation: london
Interests: Playing drums,drinking
Post by johnnymachin »
Can anyone suggest the best way to fix photos(all different sizes-some pretty big)without a mount.
I am using spacers(econospace),barrier board and an MDF backing.
Thanks,Johnny.
Re: Framing photos with no mount
Depends what you mean by 'best', the most fuss-free and effective regards flatness would be to dry or wet mount them. If they are valuable/irreplaceable - IOW if conservation is an issue then you've chosen a method that is problematic.
Spacers are not a substitute for a mount. They will restrict the edges and the photo will go wavy. If it's glossy it will look terrible. As Robo says, close-framed photos should be stuck to a board. Done properly, it could be done to 'conservation' standards, but not 'preservation' as you have effectively altered it's state.
It's like asking if you can run your car without tyres. You can. But it will knacker it.
Zolf
Organisation: Bexley's of Woodend
Interests: teaching my daughter Hungarian, experimenting with recycled timber, tree branches and other materials, woodworking, building stuff, drinking wine
Post by Zolf »
If they are valuable, you can't really do away with the mat. If they can be easily reproduced, then you could mount them onto a self adhesive foam board and use a spacer. I never place glass on anything except mats, spacers and rebates.
Bexley's of Woodend
tiny picture framing shop in a tiny town
www.bexleysofwoodend.com
Tyto
Organisation: Wild Norfolk
Interests: Photography
Post by Tyto »
If a customer insists on framing without a mount and the photos are replaceable I usually dry mount onto white display board, laminate with hotpress laminating film and then frame without glass
Zolf
Post by Zolf »
Tyto, would this be a technique that's also called block mounting? (Or partial block mounting?) Wouldn't you make more money on glass?
Not criticising, merely curious. (From Australia)
Bexley's of Woodend
What I call bock mounting is when you stick the print to a thickish block of wood (or arcylic or MDF) and either laminate or paint over with texture medium. The edges are usually painted black. There is no frame as such.
stcstc
Post by stcstc »
Painted edges - sooooooooooo old fashioned
all my blocks are edgebanded!!!
You poor soul. :( Have you tried rubbing some liniment on them? :roll:
stcstc
Post by stcstc »
no but might have a go at morso vaulting, guess that might fix it
