How to stop mount gaping ...
CanvasChris
Post by CanvasChris »
How to stop mount gaping on a large (32" x32") multi aperture mount?
Normally would stick the mount over the images but in this instance all the 9 - 8"x8" images are on Fine Art paper so have hinged them all to a mountboard and laid the double mount over.
Guess it is to do with the size and the back board bowing slightly? used 2.5mm MDF
rebate isn't that deep... 11mm .... to pack with anything solid. :sweating:
any ideas?
Re: How to stop mount gaping ...
Cut a bit of mountboard an bit bigger than the middle window. Clip the corners of about 1". Tape it to the back of the backboard in alignment with the middle window. With luck it should keep things flat. Or flat-er at least. At the same time, flip the MDF back over so if it has a slight curve it will curve in not out.
JohnMcafee
Organisation: EstLite
Interests: Developing frame pricing software
Post by JohnMcafee »
Foamcore back should sort this out.
CanvasChris
Thanks Prospero.... sounds like a plan! although I made sure the bow was going inwards when assembling
John... only got 2mm to play with as rebate only 11mm, so no room for foam :sweating: glass/3mount/back = 9
It's a method I have used many times when you want just a tiny extra bit of pressure in the right place. The secret is snipping the corners. :wink:
You could try a slightly thicker bit on something that size (3mm foamcore???), but don't overcook it.
AllFramed
Organisation: AllFramed
Post by AllFramed »
Hello Chris. Just done one similar size for 9 photo's in a fairly shallow ash moulding. I use Art-Bak which claims to be bowed to keep things flat. You can barely notice any curvature but It seems to work as it is flat against the glass.
CanvasChris
Ok.... had this frame back AGAIN today due to bowing :Slap: :Slap:
Tried Prospero's trick but to no avail.
It's 9 - 8"x8" Fine Art prints in a 9 aperture mount so didn't want to stick the mount down.... although easily replaced as I printed them myself on Canson Platine.
Any more thoughts until I incriminate myself and stick it down :sweating:
David McCormack
Organisation: Framing
Post by David McCormack »
If you can glue the window mount down to the undermount without glue getting on the prints then I would use something like Evacon-R.
Depends on how close the prints are to one another. Sometimes, certain jobs need to go with how it looks rather than reversibility, and in this case everything is replaceable, so I would glue it down and have a cuppa tea while it dries :lol:
Ricky
Restoration.Horses.
Post by Ricky »
I would Build up the back of the frame with some plain 10mm pine you can get it from B&Q in various widths,
Then use at least 5mm Foam Cor, although 10mm would be better, which should leave 2mm for an extra backing board if required.
