sealing an oval frame
Posted: Wed 22 Aug, 2012 12:45 pm
by Mrs C
good afternoon FF members
this may sound a silly question, but how does one seal an oval frame? Same technique as lining a cake tin I wonder? Cutting nicks into the tape at regular intervals so it can be made to follow the curve? Or not.
Re: sealing an oval frame
Posted: Wed 22 Aug, 2012 2:54 pm
by Mrs C
OK scrap that idea. The cake-tin lining method doesn’t work. A squeeze of sealant might be the answer.
Posted: Wed 22 Aug, 2012 3:19 pm
You could do what the 'mercans do. ATG round the edge, lay a sheet of brown paper on top and slice off the excess.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
(Like a pie crust).
What I usually do is lay strips of tape around and trim them on the outside. Wider the tape the better. I use 4" wide as default.
Posted: Wed 22 Aug, 2012 6:06 pm
by SPF
Good point prospero that's what I generally do.
Another method is to use brown kraft paper, cut oversize and dampen to stretch the paper, apply pva to the back of the frame moulding, place frame onto kraft paper and press down on frame, turn frame over and using a small roller, roll where paper is fixed to moulding to ensure the paper is adhered all round,place either thick glass or stiff board onto paper and weigh down, leave overnight to dry. In the morning remove the weight and the kraft paper should be drum tight! Cut off excess paper from moulding with scissors and then give a final trim with a scalpel/kraft knife using your index finger to guide round the outer edge of moulding to give a nice even cut and that's it.
