List Index Problem
Posted: Tue 11 May, 2004 5:02 am
by Walrus
G'day ...
Downloaded the trial (again) and reinstalled after rebuilding the computer with new board/memory/drives.
Installed fine, but whenever I attempt to alter a price, I get a "List index out of bounds (-1)" error.
Any clues?
Machine is a 2.4G Celeron with 256MB DDR and 80GB drive. WinXP pro.
Update
Posted: Tue 11 May, 2004 6:16 am
by Walrus
G'day again ...
Actually, it happens on any input - not just alterations to prices.
If I attempt to write an order, every time I attempt to input data, I get the error.
Posted: Tue 11 May, 2004 12:06 pm
by John
Hi Walrus,
Try uninstalling before you run the downloaded file estsetup.exe.
Do this from the control pannel - Add/Remove programs.
If this doesn't work, repeat the uninstall then delete the folder:-
Program Files/Est
Then install by running estsetup.exe.
There should be no need for you to re-download before trying either of the above.
Are you running other applications concurrently with EstLite?
Oooops
Posted: Tue 11 May, 2004 1:32 pm
by Walrus
G'day John ...
Wasn't clear, sorry.
It's a fresh install, on a new computer drive. Weird.
Only downloaded again because the previous d/l was swallowed by the old drive - along with a bucket of other stuff.
Posted: Tue 11 May, 2004 3:26 pm
by John
No worries Walrus, I meant for you to remove this new install and start again. I know it's a bit of a longshot, but worth a try.
Great glyph by the way :)
Eureka!
Posted: Wed 12 May, 2004 1:34 am
by Walrus
G'day John ...
Found the problem.
In options, I have changed many of the descriptions to be more meaningful for us, like "2mm Float Glass" rather than " Plain Glass."
However when I attempt to change " Plastic Glass" to something like " Acrylic Glazing" or "Anti-UV Acrylic," the error manifests itself on that setting and from then on, any subsequent attempt at input into the system.
Posted: Wed 12 May, 2004 8:09 am
by John
Looks like your configuration file, est.ini, has got damaged somehow.
Could you attach it to an email and send it to me (est@scenes.biz), so that I can clean it up for you.
It will be in the folder C:\Program Files\Est\est.ini
In the mean time I will have a look at EstLite to see if I can find the cause.
