moulding called worm wood
- Organisation: D.C. Finearts & Framing
- Interests: football Tottenham, iknow no comments please
Hi a customer came in, he had seen a moulding on a print, about 60mm wide reddish wood with a cushion top, he seemed to think it was called worm wood, apparently the framer, someone Sheffield way on, has since ceased trading, does anyone have any ideas?
- IFGL
Re: moulding called worm wood
If it is the one I'm thinking of , my parents import it direct from Italy, production has stopped on that particular one due to lack of orders, I will post a pic in the morning when I get into work.
When production starts again and we are able to get it( if it's the right moulding) I will let you know.
- IFGL
Is it this?
It's exactly 60 mm
It's exactly 60 mm
- 2013-01-23 12.49.25.jpg (1.4 MiB) Viewed 5867 times
- 60mm flat worm.jpg (793.9 KiB) Viewed 5867 times
- Organisation: thought I was
If it has a cushion top it could be Simons K360
Ian
Ian
- IFGL
oops didn't read your post properly, ours is flat
thanks for all your replies
when wood the moulding be back in production?
which one?
- IFGL
if its the picture I showed you, we have it on back order, the Italians have told us for the moment it is not in production because of lack of orders, we are hoping this means when they have enough orders it will be produced. Unfortunately that's as much as I can tell you.
simons should have their one in.
- IFGL
Confirmation from the manufactures on this moulding is it has been permanently discontinued.
