Morso Cutting Head
Posted: Wed 30 Jan, 2013 10:22 am
by Smiffy
I'm having difficulties with the cutting head on my Morso.
The problem is that the knives aren't quite forward enough to go beyond the fences, to provide the final smooth cut through the rear of the moulding.
I have been underneath, loosened the nut, and had a play with the bush, the cutting head does move a few mm either way, but not far enough. When I turn the bush too far to bring it forwards, the head just pops back, as if it cant go any further.
Any advice?
Re: Morso Cutting Head
Posted: Wed 30 Jan, 2013 11:28 am
by Roboframer
Smiffy wrote: I have been underneath, loosened the nut, and had a play with the bush,
TMI :oops:
Posted: Wed 30 Jan, 2013 12:31 pm
by Mark Thornton
If the bush adjustment doesn't have enough movement then your front handle needs its bolts slackening and the handle repositioning (towards the operator) then retightening, your bush setting will then need redoing.
Mark
Posted: Thu 31 Jan, 2013 7:57 pm
by Smiffy
Thanks Mark - i'll try my hand at it tomorrow.
I think I left a post on one of your comments last week, to do with rebate supports you have... Do you have any second hand ones left? I'm also after a waste chute, preferably second hand also...
Cheers again.
Posted: Thu 31 Jan, 2013 7:58 pm
by Smiffy
Roboframer.... Haha my bad!
Posted: Thu 31 Jan, 2013 8:29 pm
by IFGL
We had a similar problem a while back, there turned out to be a crack in the casing of the morso.
Posted: Thu 31 Jan, 2013 10:32 pm
by Smiffy
DON'T SAY THAT...!!
Posted: Fri 01 Feb, 2013 7:57 am
by Mark Thornton
Smiffy wrote:I think I left a post on one of your comments last week, to do with rebate supports you have... Do you have any second hand ones left? I'm also after a waste chute, preferably second hand also
Yes i still have afew pair of rebate supports left: http://underpinner-spares.co.uk/second_ ... emID=10193
No waste chutes yet
Mark
