Well, I've been gathering all the necessary framing equipment and goodies as I wait for the garage to finally finish it's conversion into a framing studio, but I still lack a vertical cutter (or equivalent) and work benches.
I've been looking at the Keencut Proteus and Evolution gear and would like some experienced advice on the matter. The benches seem well constructed and versatile, but are there other alternatives that I should consider?
My benches are home made using machine finished timber and MDF top surfaces. They are all very solid and robust.
The biggest bench is built onto the top of an oversize A0 plan chest and I use this for mount cutting.
I also have two medium size benches, although one doubles as a shop counter at present. One has compartments for mountboard, while the other has compartments for customers framing jobs.
The smallest bench is fitted with a 30" long old fashioned bench end gillotine, which is very useful for cutting down standard sized mountboard, or backing board pieces. It has drawers with internal box dividers for framing hardware, such as screws and D-rings with compartments below for glass, mountboard and backing off cuts. I cut these off cuts into standard sizes before storing them in the bench, this saves a lot of time and wastage.
There's another small bench planned and a small shop counter, but both of these are still waiting to be created at an appropiate time.
All of my benches are covered with Solid Kraft backing board, which getting recycled when it gets dirty on one side, as backing boards for the mirrors which I sell at auction. Very little get wasted in my business.
Build your own, custom fit, then you will know they will fit where you want them, mine are all 4"x4" timber for legs, 4"x1" stringers and 18mm chipboard tops.
Steve CEO GCF (020) Believed in Time Travel since 2035
Thanks everyone for the sensible advice. My start up costs are escalating and I need to economize pretty quickly.
I think I should consider the homemade option before sinking any more capital into expensive, stylish, prefabricated luxuries.
