Emailing informing customers when their item is ready
Hi John,
i know you've been busy.
But, i wonder if there had been any progress with integrating Est-lite with an email client to send a reminder message to customers as their work becomes "ready for collection"
This would have been incredibly handy this past few weeks for us as we managed to catch up with the backlog of work.
hope you're having a Happy Easter
- John
- Site Admin
- Organisation: Tech Support
- Interests: Forums and stuff
Thanks for the reminder Grahame.
The main thrust of recent development has been with Pre-View (major enhancement coming up).
But there are a number of new features due for EstLite. Any Day Now...
HOW Much!?
i see my question has been answered!
Oval and Circular Mounts!
when we finally get round to playing with pre-view and getting it registered, this'll be high on the list of things to "Play with".
I'm aiming for the start of May for install and full operation, but mother has other ideas...
(I'm sure i can be most persuasive, considering i got Est-lite and a computer purchased and installed about 4 months earlier than she wanted
how long do you reckon 350 Mouldings and 200 Mounts would take?...
i'm aiming for 16 hours.
Also, is it easier to work from chevrons or little "fingers" of moulding when photographing?
Grahame
Grahame
- John
- Site Admin
If you are organised and have short samples of each of your mouldings, you should be able to do about 100 mouldings in an afternoon.
I took this picture of about 100 of our mouldings when we first installed Pre-View in the shop. About 10% had to be re-photographed with better lighting. And there are always some mouldings that do not lend themselves too well to visualisation.
Most of Arqadia's profiles are online, and available to Pre-View, so you need not pgotograph any of these.
Mainline's are available in the same way, but many do not visualise well, as the samples are short.
Other suppliers will be making images of their mouldings available, so eventually photographing your own stock will not be necessary.
A single photograph could probably cover your entire mount range. The Manufacturers' swatches and sample cards could be laid out and pictured in one go
HOW Much!?
Hi John,
trying my new camera Powershot a640 with preview demo, v. 2.05
canon remote capture works fine however when i use pre-views built in capture it either says. Camera NOT connected or i've repeatedly had the error :--
CDOpenSource errorcode 0x0A000080, Device not found.
its odd, because i can take photos with the canon capture program no problem.
any ideas?
any ideas?
Log File Attached---------
11/04/2007 23:26:26:Enters TForm_Remote.FormClose
11/04/2007 23:45:21:Enters TForm_Remote.Button_StartRemoteProcessClick
11/04/2007 23:45:21:Enters StopReleasePic
11/04/2007 23:45:21:Enters Initvar
11/04/2007 23:45:21:AppException. Exception=Camera not in remote mode
11/04/2007 23:49:36:Enters TForm_Remote.FormClose
11/04/2007 23:49:41:Enters TForm_Remote.FormDestroy
11/04/2007 23:50:04:
11/04/2007 23:50:04:Remote template version started
11/04/2007 23:50:04:Date and time=11/04/2007 23:50:04
11/04/2007 23:50:04:Size of OS-version text:148
11/04/2007 23:50:04:Major OS-version:5
11/04/2007 23:50:04:Minor OS-version:1
11/04/2007 23:50:04:Build of OS-version:2600
11/04/2007 23:50:04:WinNT, full 32-bit
11/04/2007 23:50:04:Additional OS data:Service Pack 2
11/04/2007 23:50:04:Enters Initvar
11/04/2007 23:50:04:Enters TFormRemote.EnableButtons
11/04/2007 23:50:11:Enters TForm_Remote.Button_StartRemoteProcessClick
11/04/2007 23:50:15:Connect_to_powershot. Exception=CDOpenSource errorcode 0x0A000080, Device not found
11/04/2007 23:50:15:AppException. Exception=CDOpenSource errorcode 0x0A000080, Device not found
11/04/2007 23:50:27:Enters TForm_Remote.FormClose
11/04/2007 23:50:31:Enters TForm_Remote.FormDestroy
- John
- Site Admin
Close Pre-View.
Now, before plugging the camera into the computer ensure that Auto-powerdown is off and that the camera is in picture viewing mode and not in picture taking mode.
Switch on camera and connect up your USB.
The OS should recognise when the camera is plugged into the computer and display a dialog asking you to choose which application to run. When you see this, you must close the dialog without making a choice.
Run Pre-View.
If your problem persists, give me a ring (028 9024 7878).
Run Pre-View.
HOW Much!?
- John
- Site Admin
Grahame, many thanks for highlighting this problem. As we have discovered, no amount of tweaking is going to get you up and running with your A640. I'll have to roll up the sleeves and delve into the latest Canon SDK in order to resolve the difficulty in interfacing with this model.
If it is not fixed by then, I will lend you an A620 when you register Pre-View to keep you going until the A640 can be brought into play.
HOW Much!?
thanks for looking into it john, and we may very well take you up on that offer... hopefully it wont come to that!
just browsing the web for power supplies at the moment, and awaiting to enter some negative feedback on amazon about a camera bracket supplier who seems to have gone out of business.
good luck with the new SDK, i bet canon have been fiddling again
- John
- Site Admin
Thanks for the call today, Grahame.
I'm glad that the issue is now resolved, and we found that Pre-View can remotely control the Canon A640.
HOW Much!?
