The morso I recently bought doesn't have a blade guard,Ive done a google etc search
re fitting a guard.there is little info on the subject I don't see how one could be fitted without drilling or large
amounts of gaffer tape-not very pretty! anyone have any advice?
thanks
morso blade guard
- Organisation: Game of Frames
- Interests: All things zombie. I also do data recovery.
Re: morso blade guard
If you stand facing the Morso as though you were about to use it the guard holder is a circular metal disc about ~40mm across and ~20mm deep with a vertical ~10mm hole through it The blade guard support rod goes in there and is locked into position with a hand nut out of sight behind it that you have to reach over to locate.
Mike.
comma key still broken
Mike.
- David McCormack
- Organisation: Framing
to buy this bracket, but I'm not sure?
From the Lion website:
"On newer machines, it slides into a hole in the top casting. For older machines, you will need to buy the fixing bracket, Part no. DAN0005."
This is the part Mike is talking about. I think some older Morsos don't have this fitted and you may need From the Lion website:
- Organisation: Chris Lordan Photography
- Interests: Photography: social, landscape, product, wildlife. Hockey. Framing my pictures
I think Lion sell a clamp on bracket for older machines that do not have the holder fitted
https://www.lionpic.co.uk/p/14730/Clamp ... -box-guard
- Organisation: none
- Interests: woodwork
many thanks for that I will check out lion ,it doesn't appear that
clear in their description
regards
regards
