Ok, back to where we started....
I've been doing a bit of research on the net, and seem to have more answers than i had questions....
it seems that celly reacts to everything... our finishers have always blamed it on the joining... now, i'm doing the joining and have taken offence to that... it now seems that it is not a joining issue, well, i know its not as we've sanded back a few of the offending frames and have found no opening on the mitre... ok, on some of them it had been a case of the mitres opening, we sort of solved that issue by using biscuits near the top of the profile, about 3/4mm under the face of the frame, that seems to have stopped the mitres opening, but as you know we still have problems with the paint cracking... now, today, the same frame that we had an issue with yesterday has offered us another problem.... where we have the biscuits in the frame we've had to fill a few small cracks,
the biscuit machine i'm using has a very slight "wobble" (technical term
) wich every now and again causes the cut to be slightly bigger than i want it to be, so, we glue the biscuit in place, once its dried we cut and then chisel it back then fill where necessary with U-POL, we only use U-POL on the frames we're going to spray with either 2 pack or celly, now, where we've used the U-POL on the corner we have swelling and cracking of the celly... i did read last night that celly can react to a bad song on the radio...and it does react badly to many chemicals... so, i'm one step further to solving this problem.... i will keep you updated as i get more info on this... thanks for all your help and suggestions so far.... I am also looking at the moisture content issue with regards to tulip.... we do have a lot of issues with our tulip, just today i unpacked and entire delivery of tulip that is all so warped i have to send it back... this seems to be happening more and more
our suppliers told me last year that their wood is within the specified moisture content range....
but thats another issue for another day, warped wood..... what do you do ?
thanks so far guys...
have a great weekend.
Raph
