Looooooooong shot
louisesimon
Organisation: Peckham Pictures (closed)
Interests: Framing, Art, Photography
Looooooooong shot
Post by louisesimon »
Anybody got 80ft of R&H A195 in Oak that they don't need and are near enough to London for me to pick it up this weekend.
:D
louisesimon
Re: Looooooooong shot
Problem solved...A140 + table saw =A195
:clap:
Jamesnkr
Post by Jamesnkr »
A195?
Either I'm being blind, or Acrobat isn't searching properly - or R&H have a new catalogue. Are you sure?
I don't recognise A140 either... so maybe they have new mouldings.
louisesimon
Page 7 in both there 2009 catalogue and Feb 2016 catalogue.
Certainly not new mouldings, I wonder if that page is missing from your pdf, I only have a physical catalogue
David McCormack
Organisation: Framing
Post by David McCormack »
Both in my catalogue. How do you join such thin moulding and fix frame hardware?? :?
louisesimon
HI David,
A195 simply glue and underpin, fixings go on backboard.
A140 glue, 7mm underpin wedge, then place each corner in a benchtop mitre clamp, hammer panel pins close to the top and countersink. Then put frame in a strap clamp whilst glue dries. then fill the pin holes with filler. Often with a140 I'll add a subframe which acts as hanging mechanism, and gives it some strength.
I try not to offer A140 too much these days as I generally use a Hoffmann to join frames with dovetails but the minimum width for that is 10mm, so I use a hellova lot of sw3850.
Jamesnkr
Post by Jamesnkr »
How odd, p7 missing from the pdf I was looking at; now deleted.
I haven't got any of that one, sorry (as we're not far apart).
louisesimon
Thank you James here is said page
