about morso rule is it in inch or metric?
hy ifanybody can help me in telling me if the rule ofthe morso are in inch or metric? and where we can find morso second stop part the one witch have hinges so we could turn it over to pass a long frame over the rule? thanks alot
My scale is metric, I think you can get one in inches but not to sure.
You can get a second stop from Lion.
Link
http://www.lionpic.co.uk/index.php?mode ... op&x=0&y=0
Link
- Organisation: Framing Mad
It depends on what you buy! Some are metric, some are inches.... If you buy new you can have either, if you are buying second hand it will usually be stated what measure it uses.
I think nowadays it's better to have metric. Mine is imperial, and I'm always having to convert as my other, newer, machinery is metric.
- Organisation: An Urban Myth
Hi Khaled!
The Morso F comes by default with a metric rule. Lion can supply an imperial version (inches!). I have a metric one, but I did my training on the "inches" version. Personally, I found that it is much easier to set the stops on the metric version. Hope this info is helpful to you!
........Áine JGF SGF FTB
