Well, I am new to framing having attended a course last November. Initially I am framing for myself and for friends and family, but am looking to maybe build up a small business in my spare time. I am cutting mouldings with a Logan F100-2 Pro saw, then trimming mitre surfaces with a mitre trimmer. Having made some adjustments I am now reasonably happy with my mitres and they seem pretty spot on when I dry fit them.
The problem I seem to be having is when I join the frame together. I am using a Logan Pro Joiner. I realise this may be the weak point in my work flow. It seems to be a bit hit and miss whether the mitres are joined tightly when inserting the v nails. I am hazarding a guess that the clamp in the joiner is not always managing to hold the corner tight and when the v nail is inserted it seems to push the joint apart. The photos attached show my latest effort...the second photo shows a reasonable mitre...the third pic shows what two of the mitres in the frame look like - i.e. with an unacceptable gap that has appeared following inserting v nails with the Logan pinner.
As there doesn't appear to be any adjustment available with the Logan Pro Joiner clamp I am looking to possibly upgfrade my underpinner to something a bit more substantial. My budget is limited to £400-£500 and I have been looking at the Cassese CS-79, Minigraf Alfa 1/M Super, Charnwood M3 Underpinner ( at DIYFraming.com )...all either new or used. Would upgrading to any of these help overcome the mitre gap problem currently experienced using the Logan pinner? How does the Charnwood pinner compare to the Cassese - it seems to be largely modelled on the Cassese?
Apologies for the long post, but any help or advice would be gratefully accepted.
