Reusing existing frames
- Organisation: Framed of Frog Lane
- Interests: Picture framing, textile work and mixed media art
I have just had a flurry of customers asking me to make mounts to go in existing frames with new pictures (prints). Do other framers get these requests? Because it’s an existing frame and it’s theoretically just a matter of taking the old picture out, making a new mount and putting the frame back together again they’re not expecting to pay much more than the cost of the new mount. However it invariably entails grappling with horrible sticky adhesive tape, nasty sharp points, cleaning dirty glass, replacing both backing board and barrier board and having to deal with shedding and splintered bits of a knackered old frame constantly shedding between the glass and new mount…. Most of the time it would be quicker just to make a new frame from scratch.
How do others charge for all the fiddling about ~ or do you simply refuse to do repair jobs on old frames?
- Gesso&Bole
Re: Reusing existing frames
In principle, I am in favour of re-using frames that are of sufficient quality to start with. This seems to be a responsible, green, environmentally enlightened approach. However, I still need to earn a living, and the reality of the situation is often, as mentioned above, a sticky and fiddly job. Furthermore, the customer often thinks it will be a really cheap option, and it usually isn't.
My approach is to tell the customer that yes of course I can re-use their existing frames if it is practical and cost-effective to do so.
I also explain that it is at their risk - the glass may break as it comes out, the frame may not come apart cleanly etc - if it goes wrong they will have to buy new for those components.
I then price for it using my hourly labour charge - I have re-fit10, re-fit15, re-fit20 and re-fit30 programmed into my pricing system - these relate to the number of minutes I think it will take me, charged at my standard hourly rate.
Often, by the time I have upgraded them to AR glass, priced for a double mount, and new back, and hanging attachments, and the re-fit charge, it's not far off the normal bespoke price, and my profit is retained.
In reality this frequently blows their mind! They were thinking it would be cheaper than the Ikea frame they bought last summer.
If, that is the case, and they are wanting cheepy cheep. I will usually offer to cut them a new mount then and there (I have a CMC so 5 mins whilst they wait) but I will not touch the frame. This only applies to mountboard I have in stock.
The trick is to be able to educate them as to what bespoke framing is, and that it is not cheap (I often talk about hourly rates for garages or tradespeople to put this in perspective), but not to belittle or alienate people who genuinely thought that picture framing was the same price as a frame from Ikea. So by just cutting them a mount I can solve their problem, get paid something, and have a new customer who may come back with a proper job, or recommend me.
Thanks - that’s really helpful.
Totally agree about trying to be as green as possible and not chucking out perfectly serviceable frames, although my experience has sometimes been of the fiddly, badly made variety.
Good advice about educating customers.
I get a few of these for new mounts, or even some for new pieces of glass.
I say I can cut them the mount or supply the glass for them to fit it themselves.
If they want me to fit it and seal up the frame etc. I can do that for £5 - £15 depending on the size of the frame and how easy or difficult I can see the job is going to be.
- Organisation: Cliff Baughen
Perhaps someone can persuade 'The Repair Shop' to do a proper job of repairing a frame and demonstrating what's involved. They normally get one of their experts in other skills to 'fix' frames.
It's a fair proposition. but I just deduct the moulding cost which may be around a tenner or less on a medium sized frame.
But then you have to add the tear-down cost of the frame - prising out the pins and scraping the manky tape residue off.
Making good any wobbly corners and cleaning the old glass. This will likely be more than the cost of the actual frame.
If the frame is a sentimental item, OK. People seem to imagine that the frame is the main component of the whole issue,
while in reality it's a comparatively minor element.
If it's a particularly nice frame then that's one thing. An old Birds-eye Maple. Hand-gilded and nicely aged. Most period solid Oak
frames are worth reusing. These project come under the heading of Restoration.
But a cheapo frame from the '80s that came from a charity shop is not really worth the effort.
When all's said and done it is more often than not cheaper to do a completely new frame.
I'm in the same mind as Gesso&Bole, I give them a price to take the frame apart and clean glass and attach print to mount and the cost of the mount, I telll them my minimum charge for taking a frame apart is £10.00, and I charge £60.00 per hour, so a 1/2 hour job is £30.00 plus the cost of the mount. I also give them the price of just the mount, so they can fit it themselves, some customers go for this , then I see them a couple of days later asking me to fit it and they will pay for it
Since the early 90's I had used a computerized POS system with multiple fitting charge matrix's that were size generated.
examples included, but were not limited to:
regular
conservation
PIA customer
customer's materials
fire, water and bio-hazard
2 person job
overtime / rush
regular
conservation
PIA customer
2 person job
overtime / rush
I'm with Gesso&Bolle. if the frame is still structurally sound (which is rare) then I will do it.
I have an unfit charge to cover the time I spend opening the frame in front of the customer and dissecting what's inside. I'll also charge for time to clean and touch up an old frame. After that I charge as normal, having explained how I frame. Glass is tricky, the time it often takes to clean up an old piece is the same as the cost of a new piece. Unless it's very old aged glass I will replace it.
Look out also for people bringing in old antique frames. No matter what condition, there's money in those frames. And especially rare is the glass.
If the surface of the glass is rippled looking and has some little blisters or bubbles then there is value in that glass.
The best advice is to put it aside and wait for when an antique dealer comes to have some pictures tidied up. You can charge a premium on original glass.
If you do have to cut some old glass then it's important to clean both surfaces with a paste of whiting and white spirit before trying to cut it.
Why is that Dermot? The whiting and ws?
Because old glass is quite thin and can be quite fragile. And because the surface is so uneven and irregular, and if not clean, there is a danger that the glass cutter will skid and spoil the cut.
A paste of white spirit and whiting will cut through all the aged gunk and greasy film often found on old picture frames. The white spirit evaporates quickly leaving the whiting which wipes cleanly away.
Thanks Dermot, good to know!
Dermot, whiting seems to be a rather loose term these days.
Do you mean Atlantic or will Alaskan Pollock suffice? And can you recommend a recipe for the paste? (sounds like a messy business )
With the decimation of the oceans is there a sustainable alternative and can you suggest a supplier?
TIA.
TIA.
You could try a basic kipper from Tesco or other.
