I’m looking for someone who can heat press a 150x58cm map onto 5mm foam board. But needs to be fairly local to Suffolk.
I have tried googling it and yell.com and can’t find any one.
Can any one help?
Looking for someone to heat press in Suffolk.
- Interests: 4 or 5 ...
- MITREMAN
Heatsealing
Hi Guys,
I'am in Norwich If thats any help? Mobile 07849076251
Otherwise talk to Peter Stanlick at
www.framersequipment.co.uk.
Sales 01603 790333
Peters mobile 07980660240
As he sell all Hot Press Machines and products new and secondhand he will be able to put you onto a framer in your area from his data base.
Peter also runs free Hot Press training days if you were thinking of buying a machine in the furture.
Hope this will be helpful to you,
Cheers MITREMAN
Sales 01603 790333
Cheers MITREMAN
- Jonny2morsos
Hi there
You need to find someone who has a Hotpress HGP 360 (working area 1095 x 1705mm) and your best bet is to call Steve Goodall at Hotpress and ask who they have suplied in your area.
Snag is most framers (like us) go for the HGP 260 (working area 890 x 1195mm) as it can be plugged into a 13 Amp socket.
Hope this helps.
John.
Hope this helps.
John.
- MITREMAN
Dry mounting
Hi Guys,
A standard 22x26(like the old Admeco) press you can work in bites, the distance which is important is the depth ( can't remeber what it is)but you have a least another 3"-4" onto of the 26" (then you would need 2 bites then turn it round for another 2 bites to get maxiam width, the length can be any thing depending on were you have set up your press.)
Also start in the middle with the first bite (then turn round and do the opposite middle) and use a alumium cover plate with silcone paper underneath and a carrier board to avoid creases and marks.
Cheers MITREMAN
Cheers MITREMAN
- Jonny2morsos
