realhotglass wrote: I do recommend the mylar method (as suggested by Robo) for mini bats to framers here, works great because not near as much weight to worry about.
Roboframer wrote:So, Mylar/Melinex is not good for a full-sized bat?
Full size bats are simply quite heavy, much more effort to keep one mounted * long term * than a small, light mini bat.
realhotglass wrote: and some sort of non stretch line used to tie the bat down to these.
Not fishing line due to the stretching, although there may be some sort of non stretch fishing line on the market by this day and age.
Roboframer wrote:But something far narrower which is 'sharp' as opposed to flat is OK?
Again, depending on an items weight, how the back 'v' sink or stabilisers are set up, a support etc, there may not be much need for excessive pressure in support.
Using melinex straps and fining down the ends to enable tie off to 'd' rings might work ok too.
For interest, I have mounted mini bats, generally using around 1/4" wide straps near the top and bottom of the blade, with the v sink to keep stable.
IF I was going to mount a full size bat, I'd be more inclined to make those a good 3/4" width, maybe use 3 as you suggested.
The v sink might need to be a couple of decent 5mm foamcore boards, laminated together, to enable a good stable setting for the bat wedge.
I just pre read my reply (to mostly check quoted sections look ok), and when I read the above processes, I can't help but think - time, lots of it.
Roboframer wrote:It's not just the stretching anyway, fishing line will discolour and become brittle in time, it's nylon.
Polyester type line (not fishing) is available as a product somewhere (I recall seeing it), I assume same properties as Melinex / Mylar, itself a polyester.
You will find there are fishing lines on the market besides nylon too . . . polyethylene for example, another inert material that can be used for framing applications like document protection.
Roboframer wrote:If you don't mind the whole bat being shiney, (the layman may assume it was varnished?) or maybe just the handle, you could make a shaped Melinex mount with legs that pass through the mounting board. That would be extremely secure.
You can also incorporate any shields or logos on the bat in to your Melinex mount - these things are mostly stuck on and shiney, you can cut the same shape out of Melinex, with 'legs' and almost totally hide your mounting technique/materials.
I think you mean 'shinny' Robo. lol
Not a bad thought there, but again, time to do that process ?
With the bats shape, you might also find it 'crinkles' a bit, and it would be very shinny, so this would be pretty obvious.
Keep in mind too, sometimes bats are mounted wedge side up, signed down both sides of the bat.
Such a 'wrap' would be harder to do this way, and look worse, as the crinkling would be very hard to control.
But then the whole thing is easier to keep in place with the bat shape curving in top and bottom, so a couple of decent straps might just be fine there. MAybe a small sink at the toe of the bat to support too.
(Note - The acrylic mount does work with the wedge or flat sides facing up.)
If incorporating some of the shields or logos (?) on the bat, this might make such a concept more viable time wise, as you could incorporate this in the bat mounting process.
Or they are simply placed around a bat mounted / matted as usual.
Roboframer wrote:I don't have a problem with 'clamping' methods, but given the choice I'd opt for a method that does not alter the profile of the object.
I don't have a problem with Melinex for mounting items either, I recommend it often for projects, and we actually sell a fair amount of it to framers here in Oz.
In general, I have found people either want to see how something is mounted, or see nothing.
Seeing nothing is usually very hard to manage successfully, no changing / damaging an item, full reversibility, etc.
The thing is there are different ways of doing things.
Some folks like saving time / the ease of process with using such available mounts, plate holders, mighty mounts, etc . . . others don't mind saving a few $ putting the extra effort in doing something another way, formed rods, sink mounts, custom made acrylic brackets, mylar overlays, etc.
Framing is great like that, there is no real right way (design / methods etc), only different.
Keep thinking outside the obvious, this is when creativity evolves.
(And gee, this quoting stuff can get complex ! Please no quoting this any further !!)
