Hello,
I am based in Dorset near Gillingam and sell prints at shows and up to now have been making my own frames to a high spec(for 15 or so years.) I use four different mouldings , three are different colours but identical shape about 3/4 inch(this can be chopped in one go and produce excellent corners) and one is a reverse moulding about 1 inch wide made of pine. The measurements I use are 10"x 8" and 12" x 10" internal and I glue the corners with a dab for extra strength. I am loathe to have to have them made by someone else but the constant chopping is starting to get to my joints!
I am looking basically for someone to reliably make for the best possible price frames for me on a regular basis. This would be fairly large orders a few times a year. I have already asked for quotes but they have been unrealistic compared to the amount I sell the prints for. I would ideally buy the moulding and have it delivered and therefore only pay for the labour side of things. I can normally make about 150 frames a day without busting a gut.
Basically I need quality made frames for the best possible price taking into consideration that I have to make a profit! Please don't feel put out if I feel your quote is too high I have to be realistic.
I look forward to hearing from you
Thanks James
large quantities of frames needed to be made for best price
- Organisation: james frederick
- Interests: framing,woodwork
- Organisation: Artist / Journeyman Framer
- Interests: Painting in Oil / Watercolour, Industrial Heritage, Framing and Associated Crafts
Re: large quantities of frames needed to be made for best pr
Do you require backing board / glass etc?
That depends. I normally put the glass and board in myself as well, 2mm glass and 2mm mdf using one neatly positioned flexipoint on each side. I suppose I would do that to bring the price down if necessary.
- Vince442
- Organisation: Alchemy Art & Framing Ltd
- Interests: Art, photography, architecture, bonsai, travelling
I sent you a message.....did you not receive it??
Hi Vince 442,
No I haven't received any message from you. Did you send it to boscawen46@hotmail.com which is my e-mail address. Can you try again.
Regards James
Regards James
- Vince442
Hi James,
Have sent you an email.
Regards
Regards
- Organisation: Acanthus Art Framing
- Interests: Pciture frame design/hisory/restoration. Memorabilia. Theatre
Could you contact us about the large quantities of frames you require. acanthusframing@btinternet.com
OR telephone us on 01676 544 562 OR 07 958 424 757 Based near the NEC.
